BUG with [safe_z_home] config
Printer Model: Delta Custom
MCU / Printerboard: RPi / SKR
I’m running a delta printer that has print radius bigger than delta radius as it has to leave printable area to purge/wipe and to do some other things.
EVERYTHING WORKS FINE.
Because of safety i went ahead and enabled [safe_z_home] so printer returns printhead in the 0, 0 position before homing. After adding this to the printer.cfg:
[safe_z_home]
home_xy_position: 0, 0
speed: 50.0
Klipper reports: ERROR
Option ‘position_max’ in section ‘stepper_z’ must be specified
Printer is halted
AFAIK, deltas don’t have position_max in the stepper_z, heck, they don’t even have stepper_z. Without these three lines everything works perfectly.
You might call it a bug in the documentation, but safe_z_home is not compatible with the delta kinematics.
That is understandable. It’s just that I didn’t see that stated anywhere so I assumed it’s a bug.
