Building wheel for numpy error
Printer Model: cr-10
MCU / Printerboard: skr mini e3 v3
Describe your issue: when I run ~/klippy-env/bin/pip install -v numpy i get this error:
error: subprocess-exited-with-error
× Building wheel for numpy (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> See above for output.
note: This error originates from a subprocess, and is likely not a problem with pip.
full command: /home/pi/klippy-env/bin/python3 /home/pi/klippy-env/lib/python3.7/site-packages/pip/_vendor/pep517/in_process/_in_process.py build_wheel /tmp/tmp7lb9yl81
cwd: /tmp/pip-install-m2yych3k/numpy_ba9007322b864d94800023398cab5ab1
Building wheel for numpy (pyproject.toml) … error
ERROR: Failed building wheel for numpy
Failed to build numpy
ERROR: Could not build wheels for numpy, which is required to install pyproject.toml-based projects
I have the same issue
edit
OK i found the solution
Type
~/klippy-env/bin/pip install -v numpy==1.18
How did you solve the problem?
Typing the numpy==1.18.0 didn’t solve my problem because the python wheel didn’t start…
Sorry i mean
~/klippy-env/bin/pip3 install -v numpy==1.18
Try this
Thanks that solved my issues!
