Numpy won't install on pi3b Klipper
Printer Model: ender 3
MCU / Printerboard: 4.2.7 + raspberry pi3b
hello guys, I’m not able to get numpy installed for measuring resonances… I’m no pro in Linux but I tried to activate the swap file like Klipper doc says but no way to get numpy installed. could you help please?
this command worked fine:
sudo apt install python3-numpy python3-matplotlib libatlas-base-dev
But this is what appears on my ssh screen when I try to install:
hitman@Ender:~ $ ~/klippy-env/bin/pip install -v numpy
Using pip 23.2.1 from /home/hitman/klippy-env/lib/python3.9/site-packages/pip (python 3.9)
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting numpy
  Using cached numpy-1.26.0.tar.gz (15.6 MB)
  Running command pip subprocess to install build dependencies
  Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple, https://www.piwheels.org/simple
  Ignoring setuptools: markers 'python_version >= "3.12"' don't match your environment
  Ignoring colorama: markers 'os_name == "nt"' don't match your environment
  Collecting Cython<3.1,>=0.29.34
    Using cached https://www.piwheels.org/simple/cython/Cython-3.0.2-cp39-cp39-linux_armv7l.whl (10.7 MB)
  Collecting pyproject-metadata>=0.7.1
    Using cached https://www.piwheels.org/simple/pyproject-metadata/pyproject_metadata-0.7.1-py3-none-any.whl (7.4 kB)
  Collecting tomli>=1.0.0
    Using cached https://www.piwheels.org/simple/tomli/tomli-2.0.1-py3-none-any.whl (12 kB)
  Collecting packaging>=19.0 (from pyproject-metadata>=0.7.1)
    Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
  Installing collected packages: tomli, packaging, Cython, pyproject-metadata
  Successfully installed Cython-3.0.2 packaging-23.1 pyproject-metadata-0.7.1 tomli-2.0.1
  Installing build dependencies ... done
  Running command Getting requirements to build wheel
  Getting requirements to build wheel ... done
  Running command pip subprocess to install backend dependencies
  Collecting ninja>=1.8.2
    Using cached https://www.piwheels.org/simple/ninja/ninja-1.11.1-cp39-cp39-linux_armv7l.whl (132 kB)
  Collecting patchelf>=0.11.0
    Using cached patchelf-0.17.2.1-py2.py3-none-manylinux_2_17_armv7l.manylinux2014_armv7l.musllinux_1_1_armv7l.whl (381 kB)
  Installing collected packages: patchelf, ninja
  Successfully installed ninja-1.11.1 patchelf-0.17.2.1
  Installing backend dependencies ... done
  Running command Preparing metadata (pyproject.toml)
  + /home/hitman/klippy-env/bin/python /tmp/pip-install-1k2loojo/numpy_ec71125a51df47d5b81c89fc1bf1d5ee/vendored-meson/meson/meson.py setup /tmp/pip-install-1k2loojo/numpy_ec71125a51df47d5b81c89fc1bf1d5ee /tmp/pip-install-1k2loojo/numpy_ec71125a51df47d5b81c89fc1bf1d5ee/.mesonpy-no0y9xnw/build -Dbuildtype=release -Db_ndebug=if-release -Db_vscrt=md --native-file=/tmp/pip-install-1k2loojo/numpy_ec71125a51df47d5b81c89fc1bf1d5ee/.mesonpy-no0y9xnw/build/meson-python-native-file.ini
  The Meson build system
  Version: 1.2.99
  Source dir: /tmp/pip-install-1k2loojo/numpy_ec71125a51df47d5b81c89fc1bf1d5ee
  Build dir: /tmp/pip-install-1k2loojo/numpy_ec71125a51df47d5b81c89fc1bf1d5ee/.mesonpy-no0y9xnw/build
  Build type: native build
  Project name: NumPy
  Project version: 1.26.0
  C compiler for the host machine: cc (gcc 10.2.1 "cc (Raspbian 10.2.1-6+rpi1) 10.2.1 20210110")
  C linker for the host machine: cc ld.bfd 2.35.2
  C++ compiler for the host machine: c++ (gcc 10.2.1 "c++ (Raspbian 10.2.1-6+rpi1) 10.2.1 20210110")
  C++ linker for the host machine: c++ ld.bfd 2.35.2
  Cython compiler for the host machine: cython (cython 3.0.2)
  Host machine cpu family: arm
  Host machine cpu: armv7l
  Program python found: YES (/home/hitman/klippy-env/bin/python)
  Found pkg-config: /usr/bin/pkg-config (0.29.2)
  Run-time dependency python found: YES 3.9
  Has header "Python.h" with dependency python-3.9: YES
  Compiler for C supports arguments -fno-strict-aliasing: YES
  Message: During parsing cpu-dispatch: The following CPU features were ignored due to platform incompatibility or lack of support:
  "XOP FMA4"
  Test features "NEON" : Supported
  Test features "NEON_FP16" : Supported
  Test features "NEON_VFPV4" : Supported
  Test features "ASIMD" : Unsupported due to Compiler fails against the test code of "ASIMD"
  Test features "ASIMDHP" : Unsupported due to Implied feature "ASIMD" is not supported
  Test features "ASIMDFHM" : Unsupported due to Implied feature "ASIMD" is not supported
  Configuring npy_cpu_dispatch_config.h using configuration
  Message:
  CPU Optimization Options
    baseline:
      Requested : min
      Enabled   :
    dispatch:
      Requested : max -xop -fma4
      Enabled   : NEON NEON_FP16 NEON_VFPV4
  Library m found: YES
  Found CMake: /usr/bin/cmake (3.18.4)
  WARNING: CMake Toolchain: Failed to determine CMake compilers state
  Run-time dependency openblas found: NO (tried pkgconfig and cmake)
  ../../numpy/meson.build:207:4: ERROR: Problem encountered: No BLAS library detected! Install one, or use the `allow-noblas` build option (note, this may be up to 100x slower for some linear algebra operations).
  A full log can be found at /tmp/pip-install-1k2loojo/numpy_ec71125a51df47d5b81c89fc1bf1d5ee/.mesonpy-no0y9xnw/build/meson-logs/meson-log.txt
  error: subprocess-exited-with-error
  × Preparing metadata (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> See above for output.
  note: This error originates from a subprocess, and is likely not a problem with pip.
  full command: /home/hitman/klippy-env/bin/python /home/hitman/klippy-env/lib/python3.9/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py prepare_metadata_for_build_wheel /tmp/tmpml64xmd_
  cwd: /tmp/pip-install-1k2loojo/numpy_ec71125a51df47d5b81c89fc1bf1d5ee
  Preparing metadata (pyproject.toml) ... error
error: metadata-generation-failed
× Encountered error while generating package metadata.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Try:
~/klippy-env/bin/pip install -v numpy==1.25.2
Thank you so much! numpy 1.25.2 installed successfully!
For future reference:
  • v1.2.6 is brand new and no wheels are available
  • Once available, this problem should solve itself
Life saver!
Thank you very much! I have spent four days trying to install numpy in my pi4 in vain. How cool it is!
I’m having a similar issue where numpy won’t install on a pi3b / buster. Python version 2.7.16
Using pip 23.2.1 from /home/pi/klippy-env/lib/python3.7/site-packages/pip (python 3.7)
Looking in indexes: Simple index, piwheels - Simple index
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/50/e1/9b0c184f04b8cf5f3c941ffa56fbcbe936888bdac9aa7ba6bae405ac752b/numpy-1.22.0.zip (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/0a/c8/a62767a6b374a0dfb02d2a0456e5f56a372cdd1689dbc6ffb6bf1ddedbc0/numpy-1.22.1.zip (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/e9/6c/c0a8130fe198f27bab92f1b28631e0cc2572295f6b7a31e87efe7448aa1c/numpy-1.22.2.zip (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/64/4a/b008d1f8a7b9f5206ecf70a53f84e654707e7616a771d84c05151a4713e9/numpy-1.22.3.zip (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/f6/d8/ab692a75f584d13c6542c3994f75def5bce52ded9399f52e230fe402819d/numpy-1.22.4.zip (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/33/ad/fc5e3fd1077622b2b32fc3fd36176b36475b63da486eb5578d7f8fb2af29/numpy-1.23.0rc1.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/7b/bc/05e61801a3689f81c8569c057c61fd1d302e989be5c96f6ce7acee46250a/numpy-1.23.0rc2.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/a2/bf/1502d20b4a7f5d5f74c5242748834aaf8cd6ff7cb40b7c64ef58ba47a751/numpy-1.23.0rc3.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/03/c6/14a17e10813b8db20d1e800ff9a3a898e65d25f2b0e9d6a94616f1e3362c/numpy-1.23.0.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/13/b1/0c22aa7ca1deda4915cdec9562f839546bb252eecf6ad596eaec0592bd35/numpy-1.23.1.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/f4/66/17b8e95770478436bf968353c89683ce6f9e14d92e0d4fb3111c09ba18d2/numpy-1.23.2.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/0a/88/f4f0c7a982efdf7bf22f283acf6009b29a9cc5835b684a49f8d3a4adb22f/numpy-1.23.3.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/64/8e/9929b64e146d240507edaac2185cd5516f00b133be5b39250d253be25a64/numpy-1.23.4.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/42/38/775b43da55fa7473015eddc9a819571517d9a271a9f8134f68fb9be2f212/numpy-1.23.5.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/8a/b0/bb59e52e4eb90a42fbff1a90d57c45265fa3133c533e67842757068fc731/numpy-1.24.0rc1.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/da/d9/f27cf8e76b9bb015802cb347f208a32383299fd5e30965735a82a92902ae/numpy-1.24.0rc2.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/5f/c7/5ca7c100dcc85b5ef1b176bdf87be5e4392c2c3018e13cc7cdef828c6a09/numpy-1.24.0.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/ce/b8/c170db50ec49d5845bd771bc5549fe734ee73083c5c52791915f95d8e2bc/numpy-1.24.1.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/e4/a9/6704bb5e1d1d778d3a6ee1278a8d8134f0db160e09d52863a24edb58eab5/numpy-1.24.2.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/2c/d4/590ae7df5044465cc9fa2db152ae12468694d62d952b1528ecff328ef7fc/numpy-1.24.3.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.8’): https://files.pythonhosted.org/packages/a4/9b/027bec52c633f6556dba6b722d9a0befb40498b9ceddd29cbe67a45a127c/numpy-1.24.4.tar.gz (from Links for numpy) (requires-python:>=3.8)
Link requires a different Python (3.7.3 not in: ‘>=3.9’): https://files.pythonhosted.org/packages/26/de/437a60a69f7fd0c79264530a97787b2ac7394616e3661236201518f8a47d/numpy-1.25.0rc1.tar.gz (from Links for numpy) (requires-python:>=3.9)
Link requires a different Python (3.7.3 not in: ‘>=3.9’): https://files.pythonhosted.org/packages/d0/b2/fe774844d1857804cc884bba67bec38f649c99d0dc1ee7cbbf1da601357c/numpy-1.25.0.tar.gz (from Links for numpy) (requires-python:>=3.9)
Link requires a different Python (3.7.3 not in: ‘>=3.9’): https://files.pythonhosted.org/packages/cf/7a/f68d1d658a0e68084097beb212fa9356fee7eabff8b57231cc4acb555b12/numpy-1.25.1.tar.gz (from Links for numpy) (requires-python:>=3.9)
Link requires a different Python (3.7.3 not in: ‘>=3.9’): https://files.pythonhosted.org/packages/a0/41/8f53eff8e969dd8576ddfb45e7ed315407d27c7518ae49418be8ed532b07/numpy-1.25.2.tar.gz (from Links for numpy) (requires-python:>=3.9)
Link requires a different Python (3.7.3 not in: ‘<3.13,>=3.9’): https://files.pythonhosted.org/packages/29/5e/5887b95aa544a977d21f4adbc5b052897c0e730aa6408ed9903aece7f18f/numpy-1.26.0b1.tar.gz (from Links for numpy) (requires-python:<3.13,>=3.9)
Link requires a different Python (3.7.3 not in: ‘<3.13,>=3.9’): https://files.pythonhosted.org/packages/33/a9/1233954ed69e96e829e6615a6e4a68e8c99d599661edff756fb4300c9a0b/numpy-1.26.0rc1.tar.gz (from Links for numpy) (requires-python:<3.13,>=3.9)
Link requires a different Python (3.7.3 not in: ‘<3.13,>=3.9’): https://files.pythonhosted.org/packages/55/b3/b13bce39ba82b7398c06d10446f5ffd5c07db39b09bd37370dc720c7951c/numpy-1.26.0.tar.gz (from Links for numpy) (requires-python:<3.13,>=3.9)
ERROR: Ignored the following versions that require a different python version: 1.22.0 Requires-Python >=3.8; 1.22.1 Requires-Python >=3.8; 1.22.2 Requires-Python >=3.8; 1.22.3 Requires-Python >=3.8; 1.22.4 Requires-Python >=3.8; 1.23.0 Requires-Python >=3.8; 1.23.0rc1 Requires-Python >=3.8; 1.23.0rc2 Requires-Python >=3.8; 1.23.0rc3 Requires-Python >=3.8; 1.23.1 Requires-Python >=3.8; 1.23.2 Requires-Python >=3.8; 1.23.3 Requires-Python >=3.8; 1.23.4 Requires-Python >=3.8; 1.23.5 Requires-Python >=3.8; 1.24.0 Requires-Python >=3.8; 1.24.0rc1 Requires-Python >=3.8; 1.24.0rc2 Requires-Python >=3.8; 1.24.1 Requires-Python >=3.8; 1.24.2 Requires-Python >=3.8; 1.24.3 Requires-Python >=3.8; 1.24.4 Requires-Python >=3.8; 1.25.0 Requires-Python >=3.9; 1.25.0rc1 Requires-Python >=3.9; 1.25.1 Requires-Python >=3.9; 1.25.2 Requires-Python >=3.9; 1.26.0 Requires-Python <3.13,>=3.9; 1.26.0b1 Requires-Python <3.13,>=3.9; 1.26.0rc1 Requires-Python <3.13,>=3.9
ERROR: Could not find a version that satisfies the requirement numpy==1.25.2 (from versions: 1.3.0, 1.4.1, 1.5.0, 1.5.1, 1.6.0, 1.6.1, 1.6.2, 1.7.0, 1.7.1, 1.7.2, 1.8.0, 1.8.1, 1.8.2, 1.9.0, 1.9.1, 1.9.2, 1.9.3, 1.10.0.post2, 1.10.1, 1.10.2, 1.10.4, 1.11.0, 1.11.1, 1.11.2, 1.11.3, 1.12.0, 1.12.1, 1.13.0, 1.13.1, 1.13.3, 1.14.0, 1.14.1, 1.14.2, 1.14.3, 1.14.4, 1.14.5, 1.14.6, 1.15.0, 1.15.1, 1.15.2, 1.15.3, 1.15.4, 1.16.0, 1.16.1, 1.16.2, 1.16.3, 1.16.4, 1.16.5, 1.16.6, 1.17.0, 1.17.1, 1.17.2, 1.17.3, 1.17.4, 1.17.5, 1.18.0, 1.18.1, 1.18.2, 1.18.3, 1.18.4, 1.18.5, 1.19.0, 1.19.1, 1.19.2, 1.19.3, 1.19.4, 1.19.5, 1.20.0, 1.20.1, 1.20.2, 1.20.3, 1.21.0, 1.21.1, 1.21.2, 1.21.3, 1.21.4, 1.21.5, 1.21.6)
ERROR: No matching distribution found for numpy==1.25.2
If I run just ~/klippy-env/bin/pip install -v numpy, it works for several minutes then errors.
This is on 3 separate pi 3b+s
× Building wheel for numpy (pyproject.toml) did not run successfully.
│ exit code: 1
full command: /home/pi/klippy-env/bin/python3 /home/pi/klippy-env/lib/python3.7/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py build_wheel /tmp/tmpydc22k9u
cwd: /tmp/pip-install-giz8bmsr/numpy_365f24d08000431abf53d277f2595348
Building wheel for numpy (pyproject.toml) … error
ERROR: Failed building wheel for numpy
Failed to build numpy
ERROR: Could not build wheels for numpy, which is required to install pyproject.toml-based projects
My issue was resolved with ~/klippy-env/bin/pip3 install -v numpy==1.18
python 2.7? you need to update your Python to 3.7 (or latest), then install numpy 1.25.2
