Error importing Numpy after Beacon install
Printer Model: Voron 2.4
MCU / Printerboard: Octopus
Host / SBC Rpi3
klippy.zip (21.9 KB)
I am installing my first Beacon using the Quick Start guide on the website and everything seemed to install and update fine but when I when I restarted I get this Klipper error. I know nothing about Numpy and honestly not a ton about Klipper. I could use a little help if you have the time.
Klipper reports: ERROR
Internal error during connect: Error importing numpy: you should not try to import numpy from
  •    its source directory; please exit the numpy source tree, and relaunch*
  •    your python interpreter from there.*
Printer is halted
I just had this issue while installing the cartographer. I found a post on facebook that said to reinstall libopenblas-dev with sudo apt-get install libopenblas-dev, and that fixed it for me.
Perfect. That is what I needed.
Thank you for your time.
