Calibrate_shaper.py error
I was wondering if someone might be able to help me with my input shaper issue. I am producing the x and y axis .csv files, but calibrate_shaper.py is giving me an error
~/klipper/scripts/calibrate_shaper.py /tmp/resonancesx*.csv -o /tmp/shaper_calibrate_x.png
File “/home/pi/klipper/scripts/calibrate_shaper.py”, line 11, in
import numpy as np, matplotlib
File “/usr/lib/python3/dist-packages/numpy/init.py”, line 150, in
from . import random
File “/usr/lib/python3/dist-packages/numpy/random/init.py”, line 143, in < module>
from .mtrand import *
ImportError: /usr/lib/python3/dist-packages/numpy/random/mtrand.cpython-37m-arm- linux-gnueabihf.so: invalid ELF header
Looks like a messed up Python installation, e.g. mixing different versions or installing / mixing different architectures, like ARM and i386.
Did you somehow install it manually or with a package manager? Which OS? On a RPi?
Installed manually (Cloned from a raspberry pi 4 to a pi zero w 2
This works fine on my CR-10 (Rpi-4b)
But I am getting this error on my Ender 3 (Pi Zero W 2)
I’m running Fluidd
Most likely this leads to the problem. A bit over my pay-grade but IIRC Debian uses ARMEL architecture for the RPi 4 and ARMHF for the Zero
I will try installing Fluidd from scratch, worst comes to worst, I can just throw in the existing SD card.
Thanks Sineos!
I recompiled the firmware from scratch with kiauh (just to go faster) and it output the file just fine.
Thanks again!
