CAN Interface DOWN after reboot (Pi4 MainSailOS 2.2.0)
Printer Model: -
MCU / Printerboard: OctoPus PRO
Host / SBC: Raspberry Pi 4 (8GB)
klippy.log → not available yet
klippy.zip (1.4 KB)
I have a fresh installed Raspberry Pi 4 with MainSailOS 2.2.0 64 Bit.
Attached is a OctoPus Pro flashed with Katapult & Klipper 0.13 in USB/CAN Bridge Mode.
The board shows up with lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 1d50:606f OpenMoko, Inc. Geschwister Schneider CAN adapter
Bus 001 Device 003: ID 0483:3748 STMicroelectronics ST-LINK/V2
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I see also the can interface:
pi@Pi4Test:\~ $ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether d8:3a:dd:a5:ec:cf brd ff:ff:ff:ff:ff:ff
inet 192.168.30.230/24 brd 192.168.30.255 scope global dynamic noprefixroute eth0
valid_lft 172401sec preferred_lft 172401sec
inet6 fe80::8bd5:130c:9a3a:b143/64 scope link noprefixroute
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 128
link/can
4: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether d8:3a:dd:a5:ec:d0 brd ff:ff:ff:ff:ff:ff
But as you can see the Interface is in state DOWN. And I wonder why …
This is my can config:
/etc/systemd/network/25-can.network
[Match]
Name=can*
[CAN]
BitRate=1M
RestartSec=0.1s
[Link]
RequiredForOnline=no
/etc/udev/rules.d/10-can.rules
SUBSYSTEM==“net”, ACTION==“change|add”, KERNEL==“can\*”  ATTR{tx_queue_len}=“128”
Bringing up the CAN0 interface with
sudo ip link set can0 up type can bitrate 1000000
is no problem. It immediately geht UP:
3: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP group default qlen 128
link/can
Even changing the network config with
[Link]
ActivationPolicy=always-up
does not help at all.
So did I miss something to configure? Anything I could check / debug to get rid of this problem?
Best regads
Dominik
Please: For your code use the Preformatted text feature of the forum editor and not
Blockquote
Format
I don´t have that icon when I edit text.
If you tell me the normal maarkdoiwn notation I can change it.
You may try:
It’s three backticks (```)
code here
displays as:
code here
Ok fixed the formatting :slight_smile:
And I find a solution for my problem.
There seems to be a Kernel Bug. See here:
So removing the
RestartSec=0.1s
line from the config solved my issue.
After a recent update, the same thing is happening to me. I’ll try this tomorrow.
Thanks.
I released a new MainsailOS release tonight (v2.2.2). In this Release, the CAN fix is included: Release MainsailOS 2.2.2 · mainsail-crew/MainsailOS · GitHub
