I’ve Installed Octoprint and Klipper on a Windows Machine running a RaspberryPi Virtualbox and get the following error when starting Klipper:
Can not update MCU ‘mcu’ config as it is shutdown. My same printer connected to a fluidi installation is working fine but he Pi is throttling and can=t seem to fix it.
Sorry can’t seem to upload my log file as discourse says it zero byte …
I’ll paste it here.
Starting Klippy…
Args: [‘/home/pi/klipper/klippy/klippy.py’, ‘/home/pi/printer.cfg’, ‘-l’, ‘/tmp/klippy.log’]
Git version: ‘v0.10.0-364-g4d4c8d8f’
CPU: 2 core AMD PRO A8-8600B R6, 10 Compute Cores 4C+6G
Python: ‘2.7.16 (default, Oct 10 2019, 22:02:15) \n[GCC 8.3.0]’
Start printer at Sun Apr 10 10:45:38 2022 (1649580338.9 1495.9)
===== Config file =====
[stepper_x]
step_pin = PB9
dir_pin = PC2
enable_pin = !PC3
microsteps = 16
rotation_distance = 40
endstop_pin = ^PA5
position_endstop = 0
position_max = 235
homing_speed = 50
[stepper_y]
step_pin = PB7
dir_pin = PB8
enable_pin = !PC3
microsteps = 16
endstop_pin = ^PA6
position_max = 235
homing_speed = 50
step_pin = PB5
dir_pin = !PB6
enable_pin = !PC3
microsteps = 16
rotation_distance = 8
position_min = -6
position_max = 250
[safe_z_home]
home_xy_position = 157.5,120.5
speed = 100
z_hop = 10
z_hop_speed = 5
[bltouch]
sensor_pin = ^PB1
control_pin = PB0
pin_up_touch_mode_reports_triggered = True
probe_with_touch_mode = True
x_offset = -44
y_offset = -6
speed = 10
samples = 3
sample_retract_dist = 5.0
lift_speed = 40
samples_tolerance_retries = 3
z_offset = 4.021
[bed_mesh]
speed = 80
horizontal_move_z = 5
mesh_min = 18,18
mesh_max = 175,202
probe_count = 5,5
algorithm = bicubic
[screws_tilt_adjust]
screw1 = 72.5, 41.5
screw1_name = front left screw
screw2 = 198.5,41.5
screw2_name = front right screw
screw3 = 198.5,212.5
screw3_name = rear right screw
screw4 = 72.5,212.5
screw4_name = rear left screw
horizontal_move_z = 10
speed = 50
screw_thread = CW-M4
[input_shaper]
shaper_freq_x = 100
shaper_freq_y = 100
shaper_type = mzv
[gcode_macro G29]
gcode =
G28
BED_MESH_CALIBRATE
G0 X0 Y0 Z10 F6000
BED_MESH_PROFILE save=default
SAVE_CONFIG
max_extrude_only_distance = 100.0
step_pin = PB3
dir_pin = PB4
enable_pin = !PC3
microsteps = 16
rotation_distance = 33.500
nozzle_diameter = 0.400
filament_diameter = 1.750
heater_pin = PA1
sensor_pin = PC5
control = pid
pid_kp = 21.527
pid_ki = 1.063
pid_kd = 108.982
min_temp = 0
max_temp = 250
[heater_bed]
heater_pin = PA2
sensor_pin = PC4
control = pid
pid_kp = 54.027
pid_ki = 0.770
pid_kd = 948.182
min_temp = 0
max_temp = 130
[fan]
pin = PA0
serial = /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
restart_method = command
[printer]
kinematics = cartesian
max_velocity = 300
max_accel = 3000
max_accel_to_decel = 3000
max_z_velocity = 5
max_z_accel = 100
[display]
lcd_type = st7920
cs_pin = PB12
sclk_pin = PB13
sid_pin = PB15
encoder_pins = ^PB14, ^PB10
click_pin = ^!PB2
[virtual_sdcard]
path = ~/gcode_files
[display_status]
[pause_resume]
[gcode_macro PAUSE]
description = Pause the actual running print
rename_existing = PAUSE_BASE
variable_extrude = 1.0
gcode =
{% set E = printer[“gcode_macro PAUSE”].extrude|float %}
{% set x_park = printer.toolhead.axis_maximum.x|float - 5.0 %}
{% set y_park = printer.toolhead.axis_maximum.y|float - 5.0 %}
{% set max_z = printer.toolhead.axis_maximum.z|float %}
{% set act_z = printer.toolhead.position.z|float %}
{% if act_z < (max_z - 2.0) %}
{% set z_safe = 2.0 %}
{% else %}
{% set z_safe = max_z - act_z %}
PAUSE_BASE
G91
{% if printer.extruder.can_extrude|lower == ‘true’ %}
G1 E-{E} F2100
{% else %}
{action_respond_info(“Extruder not hot enough”)}
{% if “xyz” in printer.toolhead.homed_axes %}
G1 Z{z_safe} F900
G90
G1 X{x_park} Y{y_park} F6000
{% else %}
{action_respond_info(“Printer not homed”)}
[gcode_macro RESUME]
description = Resume the actual running print
rename_existing = RESUME_BASE
gcode =
{% if ‘VELOCITY’ in params|upper %}
{% set get_params = (‘VELOCITY=’ + params.VELOCITY) %}
{%else %}
{% set get_params = “” %}
G91
G1 E{E} F2100
{% else %}
RESUME_BASE {get_params}
[gcode_macro CANCEL_PRINT]
description = Cancel the actual running print
rename_existing = CANCEL_PRINT_BASE
gcode =
TURN_OFF_HEATERS
CANCEL_PRINT_BASE
[filament_switch_sensor Filament_runout_sensor]
pause_on_runout = True
runout_gcode =
G91
G1 Z20 F900 ;Raise Z away from print
G90
G1 X10 Y10 F5000 ;Move to purge bucket
G91
G1 E10 F300
G1 E20 F150
G1 E-20 F2400
G1 E-600 F1600
G90
switch_pin = !PA4
[bed_mesh default]
version = 1
points =
0.067500, -0.015000, -0.035000, -0.065833, -0.060000
0.164167, 0.054167, 0.040833, -0.005000, -0.015833
0.140000, 0.059167, 0.007500, -0.055833, -0.047500
0.181667, 0.070000, 0.027500, -0.026667, -0.045000
0.189167, 0.096667, 0.055833, 0.003333, -0.029167
tension = 0.2
min_x = 18.0
algo = bicubic
y_count = 5
mesh_y_pps = 2
min_y = 18.0
x_count = 5
max_y = 202.0
mesh_x_pps = 2
max_x = 175.0
Extruder max_extrude_ratio=0.266081
mcu ‘mcu’: Starting serial connect
mcu ‘mcu’: got {‘#receive_time’: 1497.3640117369998, u’next_clock’: 2173671424L, u’oid’: 12, u’value’: 31580, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1497.3047146390002}
mcu ‘mcu’: got {‘#receive_time’: 1497.4138297549998, u’next_clock’: 2177271424L, u’oid’: 17, u’value’: 31586, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1497.365273677}
mcu ‘mcu’: got {‘#receive_time’: 1497.663902262, u’next_clock’: 2195271424L, u’oid’: 12, u’value’: 31578, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1497.622961555}
mcu ‘mcu’: got {‘#receive_time’: 1497.714103737, u’next_clock’: 2198871424L, u’oid’: 17, u’value’: 31575, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1497.677922599}
Loaded MCU ‘mcu’ 100 commands (v0.10.0-358-g7c5b7191 / gcc: (15:8-2019-q3-1+b1) 8.3.1 20190703 (release) [gcc-8-branch revision 273027] binutils: (2.34-4+rpi1+14) 2.34)
MCU ‘mcu’ config: BUS_PINS_i2c1=PB6,PB7 BUS_PINS_i2c2=PB10,PB11 BUS_PINS_i2c1a=PB8,PB9 RESERVE_PINS_serial=PA10,PA9 BUS_PINS_spi1a=PB4,PB5,PB3 STATS_SUMSQ_BASE=256 RECEIVE_WINDOW=192 STEPPER_BOTH_EDGE=1 SERIAL_BAUD=250000 ADC_MAX=4095 BUS_PINS_spi3=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi1=PA6,PA7,PA5 PWM_MAX=255 MCU=stm32f103xe CLOCK_FREQ=72000000
MCU error during connect
File “/home/pi/klipper/klippy/klippy.py”, line 162, in _connect
cb()
File “/home/pi/klipper/klippy/mcu.py”, line 723, in _connect
config_params = self._send_get_config()
File “/home/pi/klipper/klippy/mcu.py”, line 710, in _send_get_config
self._name,))
error: Can not update MCU ‘mcu’ config as it is shutdown
Build file /home/pi/klipper/klippy/../.config(2652): Sun Apr 10 10:45:09 2022
========= Last MCU build config =========
CONFIG_LOW_LEVEL_OPTIONS=y
CONFIG_MACH_AVR is not set
CONFIG_MACH_ATSAM is not set
CONFIG_MACH_ATSAMD is not set
CONFIG_MACH_LPC176X is not set
CONFIG_MACH_STM32=y
CONFIG_MACH_RP2040 is not set
CONFIG_MACH_PRU is not set
CONFIG_MACH_LINUX is not set
CONFIG_MACH_SIMU is not set
CONFIG_BOARD_DIRECTORY=“stm32”
CONFIG_MCU=“stm32f103xe”
CONFIG_CLOCK_FREQ=72000000
CONFIG_SERIAL=y
CONFIG_FLASH_START=0x8007000
CONFIG_FLASH_SIZE=0x10000
CONFIG_RAM_START=0x20000000
CONFIG_RAM_SIZE=0x5000
CONFIG_STACK_SIZE=512
CONFIG_STM32_SELECT=y
CONFIG_MACH_STM32F103=y
CONFIG_MACH_STM32F207 is not set
CONFIG_MACH_STM32F401 is not set
CONFIG_MACH_STM32F405 is not set
CONFIG_MACH_STM32F407 is not set
CONFIG_MACH_STM32F429 is not set
CONFIG_MACH_STM32F446 is not set
CONFIG_MACH_STM32F031 is not set
CONFIG_MACH_STM32F042 is not set
CONFIG_MACH_STM32F070 is not set
CONFIG_MACH_STM32F072 is not set
CONFIG_MACH_STM32G0B1 is not set
CONFIG_MACH_STM32H743 is not set
CONFIG_MACH_STM32H750 is not set
CONFIG_MACH_STM32F1=y
CONFIG_HAVE_STM32_USBFS=y
CONFIG_HAVE_STM32_CANBUS=y
CONFIG_STM32F103GD_DISABLE_SWD is not set
CONFIG_STM32_FLASH_START_2000 is not set
CONFIG_STM32_FLASH_START_5000 is not set
CONFIG_STM32_FLASH_START_7000=y
CONFIG_STM32_FLASH_START_8000 is not set
CONFIG_STM32_FLASH_START_8800 is not set
CONFIG_STM32_FLASH_START_10000 is not set
CONFIG_STM32_FLASH_START_800 is not set
CONFIG_STM32_FLASH_START_4000 is not set
CONFIG_STM32_FLASH_START_0000 is not set
CONFIG_STM32_CLOCK_REF_8M=y
CONFIG_STM32_CLOCK_REF_12M is not set
CONFIG_STM32_CLOCK_REF_16M is not set
CONFIG_STM32_CLOCK_REF_25M is not set
CONFIG_STM32_CLOCK_REF_INTERNAL is not set
CONFIG_CLOCK_REF_FREQ=8000000
CONFIG_STM32F0_TRIM=16
CONFIG_STM32_USB_PA11_PA12 is not set
CONFIG_STM32_SERIAL_USART1=y
CONFIG_STM32_SERIAL_USART1_ALT_PB7_PB6 is not set
CONFIG_STM32_SERIAL_USART2 is not set
CONFIG_STM32_SERIAL_USART2_ALT_PD6_PD5 is not set
CONFIG_STM32_SERIAL_USART3 is not set
CONFIG_STM32_SERIAL_USART3_ALT_PD9_PD8 is not set
CONFIG_STM32_CANBUS_PA11_PA12 is not set
CONFIG_STM32_CANBUS_PB8_PB9 is not set
CONFIG_STM32_CANBUS_PD0_PD1 is not set
CONFIG_CANBUS_FREQUENCY=500000
CONFIG_SERIAL_BAUD=250000
CONFIG_USB_VENDOR_ID=0x1d50
CONFIG_USB_DEVICE_ID=0x614e
CONFIG_USB_SERIAL_NUMBER_CHIPID=y
CONFIG_USB_SERIAL_NUMBER=“12345”
CONFIG_INITIAL_PINS=“”
CONFIG_HAVE_GPIO=y
CONFIG_HAVE_GPIO_ADC=y
CONFIG_HAVE_GPIO_SPI=y
CONFIG_HAVE_GPIO_I2C=y
CONFIG_HAVE_GPIO_HARD_PWM=y
CONFIG_HAVE_GPIO_BITBANGING=y
CONFIG_HAVE_STRICT_TIMING=y
CONFIG_HAVE_CHIPID=y
CONFIG_HAVE_STEPPER_BOTH_EDGE=y
CONFIG_INLINE_STEPPER_HACK=y
Build file /home/pi/klipper/klippy/../out/klipper.dict(7269): Sun Apr 10 10:45:20 2022
Last MCU build version: v0.10.0-364-g4d4c8d8f
Last MCU build tools: gcc: (15:7-2018-q2-6) 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907] binutils: (2.31.1-12+11) 2.31.1
Last MCU build config: BUS_PINS_i2c1=PB6,PB7 RECEIVE_WINDOW=192 RESERVE_PINS_serial=PA10,PA9 BUS_PINS_i2c2=PB10,PB11 BUS_PINS_i2c1a=PB8,PB9 STEPPER_BOTH_EDGE=1 SERIAL_BAUD=250000 ADC_MAX=4095 BUS_PINS_spi3=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi1=PA6,PA7,PA5 PWM_MAX=255 MCU=stm32f103xe STATS_SUMSQ_BASE=256 BUS_PINS_spi1a=PB4,PB5,PB3 CLOCK_FREQ=72000000
Build file /home/pi/klipper/klippy/../out/klipper.elf(272228): Sun Apr 10 10:45:24 2022
mcu ‘mcu’: got {‘#receive_time’: 1497.964604451, u’next_clock’: 2216871424L, u’oid’: 12, u’value’: 31578, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1497.8018999360002}
mcu ‘mcu’: got {‘#receive_time’: 1498.0143710579998, u’next_clock’: 2220471424L, u’oid’: 17, u’value’: 31580, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1497.8018999360002}
mcu ‘mcu’: got {‘#receive_time’: 1498.263978014, u’next_clock’: 2238471424L, u’oid’: 12, u’value’: 31577, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1497.8018999360002}
mcu ‘mcu’: got {‘#receive_time’: 1498.314435866, u’next_clock’: 2242071424L, u’oid’: 17, u’value’: 31583, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1497.8018999360002}
mcu ‘mcu’: got {‘#receive_time’: 1498.563796377, u’next_clock’: 2260071424L, u’oid’: 12, u’value’: 31578, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1497.8018999360002}
mcu ‘mcu’: got {‘#receive_time’: 1498.613894123, u’next_clock’: 2263671424L, u’oid’: 17, u’value’: 31583, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1497.8018999360002}
mcu ‘mcu’: got {‘#receive_time’: 1498.863808029, u’next_clock’: 2281671424L, u’oid’: 12, u’value’: 31577, ‘#name’: u’analog_in_state’, ‘#sent_time’: 1498.786800611}
mcu ‘mcu’: got {‘#receive_time’: 1498.913966437, u’next_clock’: 2285271424L, u’oid’: 17, u’value’:
