Can not update MCU 'mcu' config as it is shutdown/Shutdown due to webhooks request
Printer Model: Creality Ender 3 v3 se
MCU / Printerboard:Creality 3D Printer Upgraded 32 Bit Silent Board Motherboard with MS35774 (GD303RET6 chipset)
klippy.log (2.1 MB)
Hello everyone.
I’m newbie to printing and just installed clipper. Following errors constantly appear:
Klipper reports: SHUTDOWN
Printer is shutdown
Can not update MCU ‘mcu’ config as it is shutdown
Error configuring printer
OS - Debian 11.
I installed klipper and other packages through Kiauh.
I see errors in log:
MCU error during connect
File “/home/orangepi/klipper/klippy/klippy.py”, line 180, in _connect
cb()
File “/home/orangepi/klipper/klippy/mcu.py”, line 717, in _connect
config_params = self._send_get_config()
File “/home/orangepi/klipper/klippy/mcu.py”, line 703, in _send_get_config
raise error(“Can not update MCU ‘%s’ config as it is shutdown” % (
mcu.error: Can not update MCU ‘mcu’ config as it is shutdown
Build file /home/orangepi/klipper/klippy/../.config(892): Wed Jan 31 16:16:25 2024
Also in log:
Transition to shutdown state: Shutdown due to webhooks request
First time i have same problem with mcu-service like in this topic:
I reinstalled OS, klipper and firmware for printer and fix this problem.
Result of command “systemctl list-dependencies”:
Thanks in advance for your help.
See MCU 'mcu' shutdown: Command request / Shutdown due to webhooks request and Can not update MCU '<name>' config as it is shutdown
Thank you for reply.
Maybe I don’t quite understand correctly, as I’m not an english speaker.
So, this situation normal ?
Is it possible to somehow remove command (M112) if it is sent automatically and is it necessary?
I didn’t find where exactly to do that…
I’m not sure what you intend to achieve.
This button or the M112 command is an emergency shutdown: It makes sure that the printer is
  • shutdown as fast as possible
  • put the machine in an safe state, e.g. turn off everything
  • prevent accidental or intentional reactivation without resetting everything
Just a strange situation.
Many people I know have same printer and installed klipper according to the same instructions and they do not have such nuans and notifications.
But if you, as a person with experience, say that this is normal, then fine.
Then I won’t worry about it.
Thank you.
