Can someone see this error log?
Printer Model: Ratrig Vcore 31
MCU / Printerboard: Octopus Pro + Ebb42
Host / SBC rpi4
hi,
Could someone please do me a favor and look at this error log?
For a few days now, the prints have been interrupted… sometimes after 20 minutes, sometimes after 2 hours…
If the print is short, it usually finishes, but the longer it is… the more likely it is to have an error.
Perhaps the log contains all the errors I’ve received recently.
I’m trying to analyze it, but I don’t know where to start.
Thanks.
klippy.zip (1.5 MB)
Primary there is this issue:
TMC 'extruder' reports GSTAT:      00000001 reset=1(Reset)
Transition to shutdown state: TMC 'extruder' reports error: GSTAT:      00000001 reset=1(Reset)
You may look here: TMC 'stepper' reports GSTAT: 00000001 reset=1(Reset)
Thanks, to the resource you gave me, I figured out what the problem was, or so I think…
I have the Canboard connected via USB, and the power supply is via a 24V line from the PSU…
Well, for that power supply, I used silicone cables, which are much more flexible than normal ones… but also much “softer,” so one of them, due to the movement of the printhead, had become frayed, and I hadn’t noticed.
It seems that the problem was caused by the printer’s metal frame, and when I touched it due to the movement of the printer…
I’m posting this whole explanation in case it helps someone.
