Can't get host to update klipper
Printer Model: Sovol sv02
MCU / Printerboard: skr 1.4 turbo
Host / SBC: rpi 3b
klippy.log klippy.log (536.1 KB)
Hello,
I’m trying to update Klipper on my printer, but I’m currently stuck. I managed to update the firmware on the mcu, bit I can’t get the host to update. I followed the guides below and I’m out of ideas.
If somebody has an idea, I would be grateful.
https://www.klipper3d.org/FAQ.html#how-do-i-upgrade-to-the-latest-software
cd ~/klipper
git pull
~/klipper/scripts/install-octopi.sh
https://www.klipper3d.org/SDCard_Updates.html
sudo service klipper stop
cd ~/klipper
git pull
make clean
make menuconfig
make
./scripts/flash-sdcard.sh /dev/ttyACM0 btt-skr-v1.3
sudo service klipper start
Here is the error message that I’m getting.
Recv: // mcu 'mcu': Command format mismatch: config is_config=%c crc=%u move_count=%hu is_shutdown=%c vs config is_config=%c crc=%u is_shutdown=%c move_count=%hu
Recv: //
Recv: // This type of error is frequently caused by running an older
Recv: // version of the firmware on the micro-controller (fix by
Recv: // recompiling and flashing the firmware).
Recv: //
Recv: // Known versions: host=v0.9.1-773-gc84956be, mcu=v0.12.0-418-g0114d72a6
Recv: //
Recv: // Once the underlying issue is corrected, use the "RESTART"
Recv: // command to reload the config and restart the host software.
Recv: // Protocol error connecting to printer
Recv: !! mcu 'mcu': Command format mismatch: config is_config=%c crc=%u move_count=%hu is_shutdown=%c vs config is_config=%c crc=%u is_shutdown=%c move_count=%hu
See MCU Protocol error caused by running an older version of the firmware
You probably did not update your MCUs correctly. If in doubt, use the same approach as for the initial flashing.
Thx for the help, but I didn’t manage to get it to work. I reinstalled everything and it works now.
