jbss71
April 14, 2025, 5:53pm
1
Printer Model: v3 se
MCU / Printerboard: STM32F103 ?
klippy (1).log (88.7 KB)
Host / SBC debian sonic pad
ive baby stepped to get this far.
When i try to save ‘config’ after a height map in Mainsail. i get this
Blockquote!! Existing config autosave is corrupted. Can’t complete SAVE_CONFIG
i have zero idea what im doing. I have copy pasted to get here . set z offset by YB videos. that looks to have saved.
ive looked for #!# and i didnt see it
all i can see is the at the bottom is this, which is supposed to be there, as far as i can tell. ive tried it without #!# on that line and same thing
Hello @jbss71 !
Please use Preformatted Text instead of Blockquote .
As for the log
Mesh Bed Leveling Complete
save_config: set [bed_mesh default] version = 1
save_config: set [bed_mesh default] points =
0.202500, 0.182500, 0.112500, 0.112500, 0.192500
0.000000, -0.007500, -0.045000, -0.072500, -0.032500
0.010000, 0.015000, -0.030000, -0.070000, -0.032500
0.110000, 0.097500, 0.045000, 0.037500, 0.070000
0.190000, 0.175000, 0.120000, 0.130000, 0.192500
save_config: set [bed_mesh default] x_count = 5
save_config: set [bed_mesh default] y_count = 5
save_config: set [bed_mesh default] mesh_x_pps = 2
save_config: set [bed_mesh default] mesh_y_pps = 2
save_config: set [bed_mesh default] algo = bicubic
save_config: set [bed_mesh default] tension = 0.2
save_config: set [bed_mesh default] min_x = 16.0
save_config: set [bed_mesh default] max_x = 198.0
save_config: set [bed_mesh default] min_y = 5.5
save_config: set [bed_mesh default] max_y = 208.98
Bed Mesh state has been saved to profile [default]
for the current session. The SAVE_CONFIG command will
update the printer config file and restart the printer.
The mesh is saved.
Have you read the line below that?
Can't read autosave from config file - autosave state corrupted
Existing config autosave is corrupted. Can't complete SAVE_CONFIG
Maybe you changed something there?
Sineos
April 14, 2025, 9:06pm
3
If nothing helps, delete the entire block starting with
You might have to redo the saved information there, such as z-offset, PID, etc.
Alternatively, post the printer.cfg file, and we’ll take a look.
jbss71
April 14, 2025, 9:29pm
4
i ended up reloading printer.cfg that fixed whatever i broke.
now im working out orca and start g code. then dealing with 1st layer height problems.
this started two weeks ago with a refurb. Sonic Pad for $55. its been out of control since.
