hey, thank you very much for your forwarding, but I don’t see there how I can explicitly adjust roaming, only how I move x and y to a safe position in front of z homed, or did I not look properly.?
Attached is my klipper log, I’m very curious if you can read something out there, since I don’t have any errors, only a Z-axis that goes too deep into bed without errors.
No, this is not the correct value if you added glass on top of your bed and didn’t do a new calibration. You need to run Z_ENDSTOP_CALIBRATE and go through the ‘paper test’ method to find the correct endstop position for your Z axis.
hello NO I don’t need that, my anycubic calibrates the Z axis automatically, the Z axis is godd when printing. I can also print very well, but when I calibrate my axis home, it moves to the print bed. That’s a different value than the actual z -axis pressure value.
hello ok first of all thanks for this answer, but I see the problem in that he always wants to move z to “0” for referencing, BUT my z “0” is not at 0 because my bed is higher. The real problem is that if he constantly drives onto the bed when homening, my calibrated Z-axis is misaligned again.
