UPD:
TMC2208/2209/2225/2226 are slightly different from TMC5160
[gcode_macro HYBRID_TPWMTHRS]
{% set speed = params.SPEED|default(50)|int %}
{% set tmc_hz = 12000000 %}
{% set x_rt = printer.configfile.settings.stepper_x.rotation_distance|float %}
{% set y_rt = printer.configfile.settings.stepper_y.rotation_distance|float %}
{% set x_rs = printer.configfile.settings.stepper_x.full_steps_per_rotation|float %}
{% set y_rs = printer.configfile.settings.stepper_y.full_steps_per_rotation|float %}
# Comment/uncomment depends on default configuration for TMC, if you already enable tpwmthrs, for speed like 1mm/s you can leave it as is
# Only for TMC22xx
# SET_TMC_FIELD STEPPER=stepper_y FIELD=en_spreadCycle VALUE=0
# SET_TMC_FIELD STEPPER=stepper_x FIELD=en_spreadCycle VALUE=0
{% set x_tpwmthrs = (tmc_hz * x_rt/x_rs/256/speed)|int %}
M118 X TPWMTHRS={x_tpwmthrs} ~ {speed} mm/s
SET_TMC_FIELD FIELD=TPWMTHRS VALUE={x_tpwmthrs} STEPPER=stepper_x
{% set y_tpwmthrs = (tmc_hz * y_rt/y_rs/256/speed)|int %}
M118 X TPWMTHRS={y_tpwmthrs} ~ {speed} mm/s
SET_TMC_FIELD FIELD=TPWMTHRS VALUE={y_tpwmthrs} STEPPER=stepper_y
And another 2 for enable/disable stealth/spread
[gcode_macro _descrease_velocity]
# initial_duration: 0.0
SET_VELOCITY_LIMIT VELOCITY={printer.configfile.settings.printer.max_velocity / 5 | int}
SET_VELOCITY_LIMIT ACCEL={printer.configfile.settings.printer.max_accel / 5 | int}
SET_VELOCITY_LIMIT ACCEL_TO_DECEL={printer.configfile.settings.printer.max_accel_to_decel / 5 | int}
SET_VELOCITY_LIMIT SQUARE_CORNER_VELOCITY={printer.configfile.settings.printer.square_corner_velocity / 5 | int}
[delayed_gcode _increase_velocity]
SET_VELOCITY_LIMIT VELOCITY={printer.configfile.settings.printer.max_velocity}
SET_VELOCITY_LIMIT ACCEL={printer.configfile.settings.printer.max_accel}
SET_VELOCITY_LIMIT ACCEL_TO_DECEL={printer.configfile.settings.printer.max_accel_to_decel}
SET_VELOCITY_LIMIT SQUARE_CORNER_VELOCITY={printer.configfile.settings.printer.square_corner_velocity}
[delayed_gcode _en_spread_y]
# TMC2209
SET_TMC_FIELD FIELD=TPWMTHRS VALUE=0 STEPPER=stepper_y
SET_TMC_FIELD STEPPER=stepper_y FIELD=en_spreadCycle VALUE=1
# TMC5160
# SET_TMC_FIELD FIELD=TPWMTHRS VALUE=1048575 TEPPER=stepper_y
[delayed_gcode _en_spread_x]
SET_TMC_FIELD FIELD=TPWMTHRS VALUE=0 STEPPER=stepper_x
SET_TMC_FIELD STEPPER=stepper_x FIELD=en_spreadCycle VALUE=1
# TMC5160
# SET_TMC_FIELD FIELD=TPWMTHRS VALUE=1048575 TEPPER=stepper_x
[delayed_gcode _dis_spread_y]
# TMC5160
# SET_TMC_FIELD FIELD=TPWMTHRS VALUE=1 STEPPER=stepper_y
[delayed_gcode _dis_spread_x]
# TMC5160
# SET_TMC_FIELD FIELD=TPWMTHRS VALUE=1 STEPPER=stepper_x
[gcode_macro SpreadCycle]
_descrease_velocity
UPDATE_DELAYED_GCODE ID=_en_spread_x DURATION=1
UPDATE_DELAYED_GCODE ID=_en_spread_y DURATION=3
UPDATE_DELAYED_GCODE ID=_increase_velocity DURATION=5
[delayed_gcode _stealth_velocity]
SET_VELOCITY_LIMIT VELOCITY={printer.configfile.settings.printer.max_velocity / 2}
SET_VELOCITY_LIMIT ACCEL={printer.configfile.settings.printer.max_accel / 2}
SET_VELOCITY_LIMIT ACCEL_TO_DECEL={printer.configfile.settings.printer.max_accel_to_decel / 2}
SET_VELOCITY_LIMIT SQUARE_CORNER_VELOCITY={printer.configfile.settings.printer.square_corner_velocity / 2}
[gcode_macro StealthChop]
_descrease_velocity
UPDATE_DELAYED_GCODE ID=_dis_spread_x DURATION=1
UPDATE_DELAYED_GCODE ID=_dis_spread_y DURATION=3
UPDATE_DELAYED_GCODE ID=_stealth_velocity DURATION=5
