Configurable HD44780 command delay (PR #7356) - feedback/review wanted
I’ve submitted a small PR making the HD44780 LCD command delay
configurable: hd44780: Make command delay configurable by SirDeath81 · Pull Request #7356 · Klipper3d/klipper · GitHub
Background: the hd44780.py driver has a hardcoded 40us minimum delay
between commands sent to the display. That’s fine for genuine HD44780
chips (Hitachi datasheet minimum is ~37us), but some cheap “clone”
displays (in my case an ACM2004 4x20 character LCD) need more margin
to display reliably. Previously the only fix was hand-patching the
hardcoded constant in hd44780.py.
The PR adds an optional hd44780_delay config option to the
[display] section, defaulting to the existing 40us so nothing changes
for users who don’t set it. Tested on a live multi-printer setup: two
printers with conforming displays stayed on the 40us default, a third
with the non-conforming clone display now uses hd44780_delay:
0.000050 and displays reliably - no more manual source patching
needed.
It’s a tiny, backward-compatible change (2 files, +8/-1 lines), but
since HD44780 displays are common in the RepRapDiscount/budget
printer space, I think it’s worth a look. Happy to answer questions
or adjust based on feedback.
Your first post but already a PR, funny. Welcome.
I really hope there is a reviewer. I think you code is the right approach since the default 40us value is still set. HD44780 LCD displays garbage (protocol timing issue, PR 5318) you might ask @Dampfwalze for reviewing. It’s a known issue with some HD44780 clones. hd44780: Make delays configurable by user. by seho85 · Pull Request #5318 · Klipper3d/klipper · GitHub you might have a look at the comments from KevinOConnor. He is the only one who really understands Klipper. Maybe a warning should/could be added in your doc changes and in your hd44780.py changes. Not every Klipper user is able to understand python code, so what should they change?
Thanks for the pointer, @hcet14 — really appreciated. I hadn’t seen
PR #5318, and I want to make sure this attempt actually addresses
KevinOConnor’s concerns from back then rather than repeating them.
I’ve just pushed an update:
  1. Configurability risk: hd44780_delay is now capped at 0.001s (1ms)
    via maxval, so it’s no longer possible to set a value large enough
    to meaningfully stall the mcu task queue - the config parser will
    reject anything above that with a clear error instead of silently
    accepting a dangerous value.
  2. Guidance for non-technical users: the Config_Reference.md entry
    now explains what the symptom looks like (garbled/randomly
    changing characters), suggests raising the value in small steps
    from the 40us default, and says to use the lowest value that
    works - no Python knowledge required.
Unlike PR #5318 (which added two separate delay knobs -
hd44780_init_delay and hd44780_pin_delay), this PR only exposes the
single existing HD44780_DELAY constant that was already there and
already used for every command - it’s not introducing new timing
concepts, just making the existing one adjustable within a bounded,
documented range. Root-causing exactly which clone chips/wiring
combinations need more margin is a fair ask, but in the meantime this
gives affected users (my own case: an ACM2004 clone at 50us) a safe,
bounded way to fix it without patching source.
@Dampfwalze - if you have time to take a look, it would be very
welcome.
P.S.: And thanks for the welcome. Until now I was just a reader because I found everything I needed :slight_smile:
My solution since was to bind mount the source file in question into the Klipper docker container, to replace it with the one from the old PR (since I prefer running with Docker Podman). But this will break eventually, so I am very happy to see movement.
This new PR is more clean, so I prefer it. Functionally they are identical. The additional initialization delay that the old PR introduced, I see that as a separate issue.
LGTM.
I am not a maintainer though, nor did I ever contribute to Klipper. I am just a programmer who happens to have a DIY 3D printer. So these are just my two cents.
Thanks for testing/confirming, @Dampfwalze — good to know it’s not just my own setup. Agreed the old PR’s extra init delay is a separate concern; keeping this one scoped to just the existing HD44780_DELAY constant was intentional.
Update: Kevin has reviewed PR #7356. His concern is that a free-form
delay value is a “foot gun” (too high a value can cause sporadic,
hard-to-debug timeouts), and he suggested a simple on/off option that
applies a fixed, known-safe extra delay for clone chips instead.
I’m happy to rework the PR that way, but I need to pick a fixed value
that covers more than just my own display. So a request to everyone
with an HD44780-type display that shows garbled or random characters:
- Which display/module do you have (name or marking, if known)?
- Which delay made it work reliably for you? My ACM2004 works at
50us (default is 40us).
@Dampfwalze - you’re the most important data point here, since you’ve
been running a different clone display with the patched file from
PR #5318. Which delay value(s) do you need for yours to work? I’ll
wait for your answer before updating the PR.
Thanks!
Congrats, your first PR and just merged.
Yes :slight_smile:
Thanks a lot for pointing the way!
Hopefully your PR ends problems with HD44780 clones regarding Klipper. Thanks to all involved.
