Configuration of BTT M8P CB1 with TMC5160T Plus
Hello,
I have a BTT Manta M8P V2.0 CB1 Mainboard connected to the TMC5160T Plus drivers. The M8P is powered with a 24V power supply, while the drivers are 48V powered.
I am just writing the Klipper configuration and want firstly to make sure the basics work without problem. But it seems a communication (SPI) issue with the drivers occurs. Whenever I try to home the axis I get the following error message:
On the M8P all 4 jumpers per driver are inserted and the jumpers for connectiong HV and VM are inserted as well on the M8P.
My config file is the following:
# This file contains common pin mappings for the BIGTREETECH Manta M8P V2.0
# To use this config, the firmware should be compiled for the
# STM32H723 with a “128KiB bootloader” “25 MHz crystal”
# and “USB (on PA11/PA12)”, “CAN bus (on PD0/PD1)” or Serial (on USART1 PA10/PA9).
# Motor1
[stepper_x]
step_pin: PE6
dir_pin: PE5
enable_pin: !PC14
rotation_distance: 40
endstop_pin: ^PF4
position_endstop: 0
position_max: 1000
homing_speed: 50
# Motor2
[stepper_y]
step_pin: PE2
dir_pin: PE1
enable_pin: !PE4
endstop_pin: ^PF3
position_endstop: 0
position_max: 1000
homing_speed: 50
# Motor3
step_pin: PB8
dir_pin: PB7
enable_pin: !PE0
rotation_distance: 8
#endstop_pin: ^PF2
#position_endstop: 0
position_max: 900
position_min: -5.0
homing_speed: 8
second_homing_speed: 3
homing_retract_dist: 3
# Motor4
[stepper_z1]
step_pin: PB4
dir_pin: PB3
enable_pin: !PB6
#endstop_pin: ^PF1
#position_max: 900
#position_min: -5.0
# homing_speed: 8
# second_homing_speed: 3
# homing_retract_dist: 3
# Motor5
[stepper_z2]
step_pin: PG13
dir_pin: PG12
enable_pin: !PG15
#endstop_pin: ^PF0
#position_max: 900
#position_min: -5.0
# homing_speed: 8
## Motor4
# The M8P only has 4 heater outputs which leaves an extra stepper
# This can be used for a second Z stepper, dual_carriage, extruder co-stepper,
# or other accesory such as an MMU
#[stepper_]
#step_pin: PB4
#dir_pin: PB3
#enable_pin: !PB6
#endstop_pin: ^PF1
# Motor6
step_pin: PG9
dir_pin: PD7
enable_pin: !PG11
rotation_distance: 33.500
nozzle_diameter: 0.4
filament_diameter: 1.75
heater_pin: PA0 # HE0
sensor_pin: PB0 # T0
sensor_type: Generic 3950
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 500
# End-Stop 5
[filament_switch_sensor material_0]
switch_pin: PF0
# Motor7
[extruder1]
step_pin: PD4
dir_pin: PD3
enable_pin: !PD6
heater_pin: PA1 # HE1
sensor_pin: PC5 # T1
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 500
# End-Stop 6
[filament_switch_sensor material_1]
switch_pin: PC15
## Motor7
#[extruder2]
#step_pin: PD4
#dir_pin: PD3
#enable_pin: !PD6
#heater_pin: PA3 # HE2
#sensor_pin: PC4 # T2
## Motor8
#[extruder3]
#step_pin: PC7
#dir_pin: PC8
#enable_pin: !PD2
#heater_pin: PA5 # HE3
#sensor_pin: PA7 # T3
[heater_bed]
heater_pin: PF5
sensor_pin: PB1 # TB
control: watermark
min_temp: 0
max_temp: 150
## Bed level support
## Bed probing hardware
### [probe]
# Z height probe. One may define this section to enable Z height probing
# hardware. When this section is enabled, PROBE and QUERY_PROBE extended
# [g-code commands](G-Codes.md#probe) become available. Also, see the
# [probe calibrate guide](Probe_Calibrate.md). The probe section also
# creates a virtual “probe:z_virtual_endstop” pin. One may set the
# stepper_z endstop_pin to this virtual pin on cartesian style printers
# that use the probe in place of a z endstop. If using
# “probe:z_virtual_endstop” then do not define a position_endstop in the
# stepper_z config section.
[output_pin probe_enable]
pin: PD12
value: 0
[gcode_macro Probe_Deploy]
  SET_PIN PIN=probe_enable VALUE=1
[gcode_macro Probe_Stow]
  SET_PIN PIN=probe_enable VALUE=0
[probe]
pin:^!PD13
# Probe detection pin. If the pin is on a different microcontroller
# than the Z steppers then it enables “multi-mcu homing”. This
# parameter must be provided.
deactivate_on_each_sample: False
# This determines if Klipper should execute deactivation gcode
# between each probe attempt when performing a multiple probe
# sequence. The default is True.
x_offset: 0.0
# The distance (in mm) between the probe and the nozzle along the
# x-axis. The default is 0.
y_offset: 0.0
# y-axis. The default is 0.
z_offset: 0.0
# The distance (in mm) between the bed and the nozzle when the probe
# triggers. This parameter must be provided.
speed: 5.0
# Speed (in mm/s) of the Z axis when probing. The default is 5mm/s.
#samples: 1
# The number of times to probe each point. The probed z-values will
# be averaged. The default is to probe 1 time.
#sample_retract_dist: 2.0
# The distance (in mm) to lift the toolhead between each sample (if
# sampling more than once). The default is 2mm.
#lift_speed:
# Speed (in mm/s) of the Z axis when lifting the probe between
# samples. The default is to use the same value as the ‘speed’
# parameter.
#samples_result: average
# The calculation method when sampling more than once - either
# “median” or “average”. The default is average.
#samples_tolerance: 0.100
# The maximum Z distance (in mm) that a sample may differ from other
# samples. If this tolerance is exceeded then either an error is
# reported or the attempt is restarted (see
# samples_tolerance_retries). The default is 0.100mm.
#samples_tolerance_retries: 0
# The number of times to retry if a sample is found that exceeds
# samples_tolerance. On a retry, all current samples are discarded
# and the probe attempt is restarted. If a valid set of samples are
# not obtained in the given number of retries then an error is
# reported. The default is zero which causes an error to be reported
# on the first sample that exceeds samples_tolerance.
activate_gcode:
  Probe_Deploy
  G4 P500 # Allow 500 milliseconds for the probe to deploy
# A list of G-Code commands to execute prior to each probe attempt.
# See docs/Command_Templates.md for G-Code format. This may be
# useful if the probe needs to be activated in some way. Do not
# issue any commands here that move the toolhead (eg, G1). The
# default is to not run any special G-Code commands on activation.
deactivate_gcode:
  Probe_Stow
# A list of G-Code commands to execute after each probe attempt
# completes. See docs/Command_Templates.md for G-Code format. Do not
# issue any commands here that move the toolhead. The default is to
# not run any special G-Code commands on deactivation.
### [bed_mesh]
#Mesh Bed Leveling. One may define a bed_mesh config section to enable
#move transformations that offset the z axis based on a mesh generated
#from probed points. When using a probe to home the z-axis, it is
#recommended to define a safe_z_home section in printer.cfg to home
#toward the center of the print area.
#See the [bed mesh guide](Bed_Mesh.md) and
#[command reference](G-Codes.md#bed_mesh) for additional information.
# Visual Examples:
# rectangular bed, probe_count = 3, 3:
# x—x—x (max_point)
# x—x—x
# (min_point) x—x—x
# round bed, round_probe_count = 5, bed_radius = r:
# x (0, r) end
# x—x—x
# (-r, 0) x—x—x—x—x (r, 0)
# x—x—x
# x (0, -r) start
[bed_mesh]
speed: 50
# The speed (in mm/s) of non-probing moves during the calibration.
# The default is 50.
horizontal_move_z: 5
# The height (in mm) that the head should be commanded to move to
# just prior to starting a probe operation. The default is 5.
mesh_min: 0, 0
# Defines the minimum X, Y coordinate of the mesh for rectangular
# beds. This coordinate is relative to the probe’s location. This
# will be the first point probed, nearest to the origin. This
# parameter must be provided for rectangular beds.
mesh_max: 1000, 1000
# Defines the maximum X, Y coordinate of the mesh for rectangular
# beds. Adheres to the same principle as mesh_min, however this will
# be the furthest point probed from the bed’s origin. This parameter
# must be provided for rectangular beds.
probe_count: 5, 5
# For rectangular beds, this is a comma separate pair of integer
# values X, Y defining the number of points to probe along each
# axis. A single value is also valid, in which case that value will
# be applied to both axes. Default is 3, 3.
#fade_start: 1.0
# The gcode z position in which to start phasing out z-adjustment
# when fade is enabled. Default is 1.0.
#fade_end: 0.0
# The gcode z position in which phasing out completes. When set to a
# value below fade_start, fade is disabled. It should be noted that
# fade may add unwanted scaling along the z-axis of a print. If a
# user wishes to enable fade, a value of 10.0 is recommended.
# Default is 0.0, which disables fade.
#fade_target:
# The z position in which fade should converge. When this value is
# set to a non-zero value it must be within the range of z-values in
# the mesh. Users that wish to converge to the z homing position
# should set this to 0. Default is the average z value of the mesh.
#split_delta_z: .025
# The amount of Z difference (in mm) along a move that will trigger
# a split. Default is .025.
#move_check_distance: 5.0
# The distance (in mm) along a move to check for split_delta_z.
# This is also the minimum length that a move can be split. Default
# is 5.0.
#mesh_pps: 2, 2
# A comma separated pair of integers X, Y defining the number of
# points per segment to interpolate in the mesh along each axis. A
# “segment” can be defined as the space between each probed point.
# The user may enter a single value which will be applied to both
# axes. Default is 2, 2.
algorithm: lagrange
# The interpolation algorithm to use. May be either “lagrange” or
# “bicubic”. This option will not affect 3x3 grids, which are forced
# to use lagrange sampling. Default is lagrange.
#bicubic_tension: .2
# When using the bicubic algorithm the tension parameter above may
# be applied to change the amount of slope interpolated. Larger
# numbers will increase the amount of slope, which results in more
# curvature in the mesh. Default is .2.
#zero_reference_position:
# An optional X,Y coordinate that specifies the location on the bed
# where Z = 0. When this option is specified the mesh will be offset
# so that zero Z adjustment occurs at this location. The default is
# no zero reference.
#faulty_region_1_min:
#faulty_region_1_max:
# Optional points that define a faulty region. See docs/Bed_Mesh.md
# for details on faulty regions. Up to 99 faulty regions may be added.
# By default no faulty regions are set.
#adaptive_margin:
# An optional margin (in mm) to be added around the bed area used by
# the defined print objects when generating an adaptive mesh.
#scan_overshoot:
# The maximum amount of travel (in mm) available outside of the mesh.
# For rectangular beds this applies to travel on the X axis, and for round beds
# it applies to the entire radius. The tool must be able to travel the amount
# specified outside of the mesh. This value is used to optimize the travel
# path when performing a “rapid scan”. The minimum value that may be specified
# is 1. The default is no overshoot.
### [bed_tilt]
# Bed tilt compensation. One may define a bed_tilt config section to
# enable move transformations that account for a tilted bed. Note that
# bed_mesh and bed_tilt are incompatible; both cannot be defined.
# See the [command reference](G-Codes.md#bed_tilt) for additional
# information.
#[bed_tilt]
#x_adjust: 0
# The amount to add to each move’s Z height for each mm on the X
# axis. The default is 0.
#y_adjust: 0
# The amount to add to each move’s Z height for each mm on the Y
#z_adjust: 0
# The amount to add to the Z height when the nozzle is nominally at
# 0, 0. The default is 0.
# The remaining parameters control a BED_TILT_CALIBRATE extended
# g-code command that may be used to calibrate appropriate x and y
# adjustment parameters.
#points:
# A list of X, Y coordinates (one per line; subsequent lines
# indented) that should be probed during a BED_TILT_CALIBRATE
# command. Specify coordinates of the nozzle and be sure the probe
# is above the bed at the given nozzle coordinates. The default is
# to not enable the command.
#speed: 50
#horizontal_move_z: 5
### [bed_screws]
# Tool to help adjust bed leveling screws. One may define a [bed_screws]
# config section to enable a BED_SCREWS_ADJUST g-code command.
# See the
# [leveling guide](Manual_Level.md#adjusting-bed-leveling-screws) and
# [command reference](G-Codes.md#bed_screws) for additional information.
[bed_screws]
screw1: 500, 1000
# The X, Y coordinate of the first bed leveling screw. This is a
# position to command the nozzle to that is directly above the bed
# screw (or as close as possible while still being above the bed).
# This parameter must be provided.
screw1_name: Screw back-middle
# An arbitrary name for the given screw. This name is displayed when
# the helper script runs. The default is to use a name based upon
# the screw XY location.
#screw1_fine_adjust:
# An X, Y coordinate to command the nozzle to so that one can fine
# tune the bed leveling screw. The default is to not perform fine
# adjustments on the bed screw.
screw2: 0, 500
screw2_name: Screw left
#screw2_fine_adjust:
screw3: 1000, 500
screw3_name: Screw right
# Additional bed leveling screws. At least three screws must be
# defined.
horizontal_move_z: 25
# when moving from one screw location to the next. The default is 5.
#probe_height: 0
# The height of the probe (in mm) after adjusting for the thermal
# expansion of bed and nozzle. The default is zero.
speed: 50
probe_speed: 5
# The speed (in mm/s) when moving from a horizontal_move_z position
# to a probe_height position. The default is 5.
### [screws_tilt_adjust]
# Tool to help adjust bed screws tilt using Z probe. One may define a
# screws_tilt_adjust config section to enable a SCREWS_TILT_CALCULATE
# g-code command.
# See the
# [leveling guide](Manual_Level.md#adjusting-bed-leveling-screws-using-the-bed-probe)
# and [command reference](G-Codes.md#screws_tilt_adjust) for additional
# information.
#[screws_tilt_adjust]
#screw1:
# The (X, Y) coordinate of the first bed leveling screw. This is a
# position to command the nozzle to so that the probe is directly
# above the bed screw (or as close as possible while still being
# above the bed). This is the base screw used in calculations. This
#screw1_name:
#screw2:
#screw2_name:
# Additional bed leveling screws. At least two screws must be
# defined.
#speed: 50
#screw_thread: CW-M3
# The type of screw used for bed leveling, M3, M4, or M5, and the
# rotation direction of the knob that is used to level the bed.
# Accepted values: CW-M3, CCW-M3, CW-M4, CCW-M4, CW-M5, CCW-M5.
# Default value is CW-M3 which most printers use. A clockwise
# rotation of the knob decreases the gap between the nozzle and the
# bed. Conversely, a counter-clockwise rotation increases the gap.
### [z_tilt]
# Multiple Z stepper tilt adjustment. This feature enables independent
# adjustment of multiple z steppers (see the “stepper_z1” section) to
# adjust for tilt. If this section is present then a Z_TILT_ADJUST
# extended [G-Code command](G-Codes.md#z_tilt) becomes available.
[z_tilt]
z_positions:
500, 1000
0, 500
1000, 500
# indented) describing the location of each bed “pivot point”. The
# “pivot point” is the point where the bed attaches to the given Z
# stepper. It is described using nozzle coordinates (the X, Y position
# of the nozzle if it could move directly above the point). The
# first entry corresponds to stepper_z, the second to stepper_z1,
# the third to stepper_z2, etc. This parameter must be provided.
500, 960
40, 500
960, 500
# indented) that should be probed during a Z_TILT_ADJUST command.
# Specify coordinates of the nozzle and be sure the probe is above
# the bed at the given nozzle coordinates. This parameter must be
# provided.
speed: 50
retries: 3
# Number of times to retry if the probed points aren’t within
# tolerance.
retry_tolerance: 0.05
# If retries are enabled then retry if largest and smallest probed
# points differ more than retry_tolerance. Note the smallest unit of
# change here would be a single step. However if you are probing
# more points than steppers then you will likely have a fixed
# minimum value for the range of probed points which you can learn
# by observing command output.
### [quad_gantry_level]
# Moving gantry leveling using 4 independently controlled Z motors.
# Corrects hyperbolic parabola effects (potato chip) on moving gantry
# which is more flexible.
# WARNING: Using this on a moving bed may lead to undesirable results.
# If this section is present then a QUAD_GANTRY_LEVEL extended G-Code
# command becomes available. This routine assumes the following Z motor
#configuration:
# |Z1 Z2|
# | x-------- |
# |Z Z3|
#Where x is the 0, 0 point on the bed
#[quad_gantry_level]
#gantry_corners:
# A newline separated list of X, Y coordinates describing the two
# opposing corners of the gantry. The first entry corresponds to Z,
# the second to Z2. This parameter must be provided.
#points:
# A newline separated list of four X, Y points that should be probed
# during a QUAD_GANTRY_LEVEL command. Order of the locations is
# important, and should correspond to Z, Z1, Z2, and Z3 location in
# order. This parameter must be provided. For maximum accuracy,
# ensure your probe offsets are configured.
#speed: 50
#max_adjust: 4
# Safety limit if an adjustment greater than this value is requested
# quad_gantry_level will abort.
#retries: 0
# tolerance.
#retry_tolerance: 0
### [skew_correction]
# Printer Skew Correction. It is possible to use software to correct
# printer skew across 3 planes, xy, xz, yz. This is done by printing a
# calibration model along a plane and measuring three lengths. Due to
# the nature of skew correction these lengths are set via gcode. See
# [Skew Correction](Skew_Correction.md) and
# [Command Reference](G-Codes.md#skew_correction) for details.
#[skew_correction]
### [z_thermal_adjust]
# Temperature-dependant toolhead Z position adjustment. Compensate for vertical
# toolhead movement caused by thermal expansion of the printer’s frame in
# real-time using a temperature sensor (typically coupled to a vertical section
# of frame).
# See also: [extended g-code commands](G-Codes.md#z_thermal_adjust).
#[z_thermal_adjust]
#temp_coeff:
# The temperature coefficient of expansion, in mm/degC. For example, a
# temp_coeff of 0.01 mm/degC will move the Z axis downwards by 0.01 mm for
# every degree Celsius that the temperature sensor increases. Defaults to
# 0.0 mm/degC, which applies no adjustment.
#smooth_time:
# Smoothing window applied to the temperature sensor, in seconds. Can reduce
# motor noise from excessive small corrections in response to sensor noise.
# The default is 2.0 seconds.
#z_adjust_off_above:
# Disables adjustments above this Z height [mm]. The last computed correction
# will remain applied until the toolhead moves below the specified Z height
# again. The default is 99999999.0 mm (always on).
#max_z_adjustment:
# Maximum absolute adjustment that can be applied to the Z axis [mm]. The
# default is 99999999.0 mm (unlimited).
#sensor_type:
#sensor_pin:
#min_temp:
#max_temp:
# Temperature sensor configuration.
# See the “extruder” section for the definition of the above
# parameters.
#gcode_id:
# See the “heater_generic” section for the definition of this
# parameter.
## Customized homing
### [safe_z_home]
# Safe Z homing. One may use this mechanism to home the Z axis at a
# specific X, Y coordinate. This is useful if the toolhead, for example
# has to move to the center of the bed before Z can be homed.
#[safe_z_home]
#home_xy_position:
# A X, Y coordinate (e.g. 100, 100) where the Z homing should be
# performed. This parameter must be provided.
#speed: 50.0
# Speed at which the toolhead is moved to the safe Z home
# coordinate. The default is 50 mm/s
#z_hop:
# Distance (in mm) to lift the Z axis prior to homing. This is
# applied to any homing command, even if it doesn’t home the Z axis.
# If the Z axis is already homed and the current Z position is less
# than z_hop, then this will lift the head to a height of z_hop. If
# the Z axis is not already homed the head is lifted by z_hop.
# The default is to not implement Z hop.
#z_hop_speed: 15.0
# Speed (in mm/s) at which the Z axis is lifted prior to homing. The
# default is 15 mm/s.
#move_to_previous: False
# When set to True, the X and Y axes are reset to their previous
# positions after Z axis homing. The default is False.
### [homing_override]
# Homing override. One may use this mechanism to run a series of g-code
# commands in place of a G28 found in the normal g-code input. This may
# be useful on printers that require a specific procedure to home the
# machine.
#[fan_generic soc-fan]
#pin: host:gpio79 #CB1
#pin: host:gpio26 #CM4
# Fan0
[fan]
pin: PF7
## Fan1
#[heater_fan fan1]
#pin: PF9
## Fan2
#[heater_fan fan2]
#pin: PF6
## Fan3
#[heater_fan fan3]
#pin: PF8
## Fan4
#[heater_fan fan4]
#pin: PA4
## Fan5
#[heater_fan fan5]
#pin: PA6
#tachometer_pin: PC2
## Fan6
#[heater_fan fan6]
#pin: PA2
#tachometer_pin: PC1
serial: /dev/serial/by-id/usb-Klipper_stm32h723xx_4A0016000551323235363233-if00
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
# TMC5160 configuration
# # Motor1
[tmc5160 stepper_x]
cs_pin: PC13
spi_bus: spi1
run_current: 1.100
sense_resistor: 0.022
stealthchop_threshold: 999999
# Motor2
[tmc5160 stepper_y]
cs_pin: PE3
spi_bus: spi1
run_current: 1.100
# Motor3
[tmc5160 stepper_z]
cs_pin: PB9
spi_bus: spi1
run_current: 1.100
# Motor4
[tmc5160 stepper_z1]
cs_pin: PB5
spi_bus: spi1
run_current: 1.100
# Motor5
[tmc5160 stepper_z2]
cs_pin: PG14
spi_bus: spi1
run_current: 1.100
# Motor6
# [tmc5160 extruder]
# cs_pin: PG10
# spi_bus: spi1
# run_current: 1.100
# sense_resistor: 0.022
# stealthchop_threshold: 999999
# # Motor7
# [tmc5160 extruder1]
# cs_pin: PD5
# spi_bus: spi1
## Motor8
#[tmc2130 extruder3]
#cs_pin: PC6
#spi_software_mosi_pin: PG6
#spi_software_miso_pin: PG7
#spi_software_sclk_pin: PG8
#run_current: 0.800
#stealthchop_threshold: 999999
[board_pins]
aliases:
\# EXP1 header
EXP1_1=PE7, EXP1_2=PG1,
EXP1_3=PG0, EXP1_4=PF15,
EXP1_5=PF14, EXP1_6=PF13,    # Slot in the socket on this side
EXP1_7=PF12, EXP1_8=PF11,
EXP1_9=<GND>, EXP1_10=<5V>,
\# EXP2 header
EXP2_1=PE13, EXP2_2=PE12,
EXP2_3=PE15, EXP2_4=PE11,
EXP2_5=PE10, EXP2_6=PE14,      # Slot in the socket on this side
EXP2_7=PE8, EXP2_8=<RST>,
EXP2_9=<GND>, EXP2_10=<NC>
# See the sample-lcd.cfg file for definitions of common LCD displays.
#[adxl345]
#cs_pin: PA15
#spi_bus: spi3a
#[bltouch]
#sensor_pin: PD13
#control_pin: PD12
## Proximity switch
#[probe]
#pin: PD8
#[output_pin ps_on_pin]
#pin: PD14
#[neopixel my_neopixel_1]
#pin: PD15
#[hall_filament_width_sensor]
#adc1: PC0
#adc2: PF10
config-20250829-201213.zip (8.1 KB)
Can someone please help me fixing this issue?
Thanks.
Hello @Mattias !
Instead of deleting the template, please stick to it: How-To Ask for Help.
Please try again.
