voron 2.4 special edi…
R. pi4 + mks monsters8 v2 klippy (4).log (2.4 MB)
Hello everyone… Friends, Clipper does not apply the settings I made in Cura Slicer. It applies the settings we made in config.cfg. For example, whether the part fan is on or off… I select the part fan as off in the curada slicing settings. But when you start printing, the part fan comes on. I cannot turn off the fan neither on the computer nor on the clipper screen.
Yes. I have already configured the macro settings according to my own system. For example, what I want to do is; Being able to change the fan speed while the printer continues writing parts. I turn off the fan setting while slicing. and applies the g-code macro while starting to print the part. but when he starts writing the track the fan doesn’t stop. It does not allow me to make adjustments from the console or the clipper screen.
It’s hard to understand what you’re trying to do, but if you mean you want to be able to manually control the fan while a macro is executing, you can’t do that. Any manual changes to the man settings will not take effect until after the macro has finished executing.
