Klipper not taking settings from slicer or saving changes from dashboard
Printer Model: Ender 3 Pro with CR Touch and direct drive extruder
MCU / Printerboard: 4.2.2
Host / SBC: Raspberry Pi 3B+
klippy.log:
Klipper not retaining pressure advance settings and it’s not taking the temps from my slicer, it’s staying on the default temperature. I’ve been trying to get a calibration cube to print with Klipper now for 2 weeks and am about ready to chuck the entire printer in the river I’m so frustrated with it.
klippy(1).log (714.6 KB)
Seriously if anyone has a step by step troubleshooting guide that they like please let me know, I’m just at my wits end. I’ve been able to get a bed mesh created but that’s about the only useful thing I’ve been able to get Klipper to do.
Hello @mjmiller !
What is the start code in the slicer is looking like?
Do you passe the values over to Klipper within that?
What slicer are you using?
So I’m completely new to Klipper I’m using Cura, I just have START_PRINT to call the start print macro. I have the defaults in the START_PRINT Macro and that’s what gets loaded everytime. I suspect Cura isn’t passing something correctly and it’s probably user error. I cobbled together the macro I’m using from stuff online.
Here is the macro:
[gcode_macro START_PRINT]
    {% set BED_TEMPERATURE = params.BED_TEMP|default(75)|float %}
    {% set EXTRUDER_TEMPERATURE = params.EXTRUDER_TEMP|default(210)|float %}
    {% set OFFSET=params.OFFSET|default(0)|float %}
    # Wait for bed to reach temperature
    M190 S{BED_TEMPERATURE}
    # Home the printer
    G28
    # Load Mesh Bed Level
    G29
    # Move close to the coordinates origin
    BED_MESH_PROFILE LOAD=default
    G1 Z2.0 F240
    G1 X2.0 Y10 F3000
    # Start bed heating
    M117 Heating bed
    M140 S{BED_TEMPERATURE}
    # Use absolute coordinates
    G90
    # Reset the G-Code Z offset (adjust Z offset if needed)
    SET_GCODE_OFFSET Z={OFFSET}
    #M190 S{BED_TEMP}
    # Start nozzle heating
    M117 Heating nozzle
    M104 S{EXTRUDER_TEMPERATURE}
    # Set and wait for nozzle to reach temperature
    M109 S{EXTRUDER_TEMPERATURE}
    # Prime line
    PRIME_EXTRUDER
    M117 Printing
Cura, I have profiles from when I was using Marlin that I don’t really want to have to set up from scratch, but it is what it is right now.
Please use the Preformatted Text feature of the forum editor for posting code snippets:
Format
And please attach the start G-code of the Slicer
START_PRINT
Is the entire start code in CURA. I used to have a bunch of other stuff in there for Marlin because I was using a different flavor of it than the stock creality. I should still have it somewhere if you need to see it.
So there are no heating parameters passed over to the printer.
You may have a look here: Using START_PRINT and END_PRINT Macros
Thank you, that part seems to have worked, if I can pick your brain about one more thing, settings like pressure advance don’t get saved. And while I can calibrate my z offset it doesn’t load it correctly even though it’s saved in the file. My call looks like this:SET_GCODE_OFFSET Z={z_offset} but when I try to run a print, it says it can’t parse it. If I comment out that line, it works, but doesn’t use the z offset even though it’s saved in the generated section as z_offset. I assume there’s a syntax error but I don’t know what it is.
After calibration, did you perform a SAVE_CONFIG to store the new values?
I believe so this is in the generated section:
#*# [bltouch]
#*# z_offset = 1.730
But when I start a print it just says z offset 0 and I have to tune it in the first few seconds of the print while it’s laying down a brim.
This is because your START_PRINT macro is setting the z offset to 0. You need to pass the desired offset to START_PRINT using the OFFSET parameter just like you did with the temperature parameters.
Thank you so much! Is there a comprehensive list of klipper parameters somewhere so I don’t have these kind of problems in the future?
START_PRINT is a custom macro that you chose to use, not part of Klipper. For a comprehensive list of parameters that it cares about all you have to do is read the macro.
I would like a full list of parameters klipper can access. I have what I need with the macro. But I would prefer to solve my own problems with the documentation rather than constantly ask for help. I have yet to find a list of parameters that klipper can reference in macros. As I suspect I’ll be creating more custom macros once I become more comfortable with Klipper. Appreciate your help though.
See Example: Search Printer Objects. It should be largely self-explanatory.
Perfect, thank you.
I think @flowerysong misunderstood what you were requesting because “parameters” in this context usually refers to the variables/arguments that can be passed to and used by a macro. And since those are defined in the macro and can be anything you want, there obviously is no list of them except in the macro itself.
