Example: Search Printer Objects
This macro will allow you to type SEARCH_VARS S={some word} from the terminal and
it will respond with all of the matching items in the printer object.
Say I wanted to know what the name and path of for the value of the currently loaded bed
mesh. I could do type search_vars s=profile in my terminal and it will respond with
any items containing the word ‘profile’.
$ SEARCH_VARS s="profile"
// printer.bed_mesh.profile_name : default
Additionally, omitting the “s” parameter will just dump out literally everything and probably catch fire.
You have been warned.
[gcode_macro SEARCH_VARS]
    {% set search = params.S|lower %}
    {% set ns = namespace() %}
    {% for item in printer  %}
        {% if ' ' in item %}
            {% set ns.path = ['printer', "['%s']" % (item), ''] %}
        {% else %}
            {% set ns.path = ['printer.', item, ''] %}
        {% if search in ns.path|lower %}
            { action_respond_info(ns.path|join) }
        {% if printer[item].items() %}
            {% for childkey, child in printer[item].items() recursive %}
                {% set ns.path = ns.path[:loop.depth|int + 1] %}
                {% if ' ' in childkey %}
                    {% set null = ns.path.append("['%s']" % (childkey)) %}
                {% else %}
                    {% set null = ns.path.append(".%s" % (childkey)) %}
                {% if child is mapping  %}
                    { loop(child.items()) }
                {% else %}
                        { action_respond_info("%s : %s" % (ns.path|join, child)) }
            {% endfor %}
    {% endfor %}
I know this is really old, but I think it is close to what I need for something I’m working on. See:
Indirectly indexing through extruder objects - General Discussion - Klipper
It makes sense somewhat (I’m still a novice) that what I was trying to do is different from how you can do macros because this involves paths. It looks like this could be what I need to build the path, but I think the last piece I need to figure out is how do I capture the value that the path references.
So say I had something like below. What would I put where the ???s are to pull the value that the ns.path|join references? i.e. the value of printer.extruder1.temperature
[gcode_macro test]
variable_temp: 0
variable_ext: "extruder1"
    {% set ns.path = ['printer.', ext, 'temperature'] %}
    SET_GCODE_VARIABLE MACRO=test VARIABLE=temp VALUE=???
Well I found what I needed and it actually had nothing to do with paths. See the solution of my post linked above.
Hi, I tried to dump the printer variable (for science :sweat_smile: ) but it fails on this very macro
Error evaluating 'gcode_macro SEARCH_VARS:gcode': TypeError: argument of type 'int' is not iterable
  File "/home/biqu/klipper/klippy/extras/gcode_macro.py", line 70, in render
    return str(self.template.render(context))
  File "/home/biqu/klippy-env/lib/python3.9/site-packages/jinja2/environment.py", line 1090, in render
    self.environment.handle_exception()
  File "/home/biqu/klippy-env/lib/python3.9/site-packages/jinja2/environment.py", line 832, in handle_exception
    reraise(*rewrite_traceback_stack(source=source))
  File "/home/biqu/klippy-env/lib/python3.9/site-packages/jinja2/_compat.py", line 28, in reraise
    raise value.with_traceback(tb)
  File "<template>", line 16, in top-level template code
  File "<template>", line 26, in template
  File "<template>", line 19, in template
