Delta Tower Angle Setup
Im trying to setup a delta the way i want and having some troubles.
Currently with the attached print.cfg The Y axis seems to be inverted. The printer homes properly to the max z height and otherwise moves correctly. Its just when i use the jog controls the Y axis moves the opposite way to what i want.
Here is a diagram on how it moves and how id like it to move:
Here is the printer.cfg printer.cfg (10.7 KB)
Any help would be appreciated.
Alex
You may assign the steppers in another way?
Thanks for your reply. I changed it like you suggested which aligned the Y axis correctly but it still left the x axis moving in the opposite direction to what i wanted. I think i may have drawn my image incorrectly to start with!
So i swapped the pin assignments on tower A and C and it is now moving as i wanted.
Thanks
