Did I brick my board
Printer Model:
MCU / Printerboard:
…board is BTT octopus v1.1
I can not get a klippy log
printer upgraded Tronxy x5sa
i notice there was an icon on my mailsail page to update so I did and now I can not get back inot my board. I have tried to reflash the firmware but it wont change to firmware.cur
I can not get a klipper log
Try here, a simple search would have got you here.
I went through all the steps but it would not do anything when i tried make
Then I would suggest you did not follow the steps because Make will either compile the firmware or give you a error - you could try make clean then retry make
I am sorry not sure I can be of anymore help very hard for me when flying blind do not have the energy for that.
I will try it again . I also installed the jumper to try and power it from the usb-c and no light come on the board
Ok went back through the whole thing . Hit q then Y to save then this pops up . I type make and this is what it saysb
The link I sent you is one option to try if you feel comfortable with those command it makes no mention of KIAUH, I do not use that software so I am of no help with it.
You can I believe use KIAUH to flash your firmware so use that and ignore the link I gave but you can not use invalid commands inside of KIAUH from the link I send , use one or the other
Instructions on recovering the bootloader:
