Different versions in update manager / installed
Printer Model: Vcore 31
MCU / Printerboard: Octopus Pro 446 + EBB42 by USB
klippy.log (981.2 KB)
Hi
I reinstalled klipper, and when I almost had it I updated…
Showing this error
but in update manager in Fluidd can see…
Why error say that i have installed in MCU ver: 0.12.0.74 but in Update manager of Fluidd i can see that version installed its 0.12.0.85?
Can force reinstall last update? How?
See MCU Protocol error caused by running an older version of the firmware for a general explanation.
This cannot be solved from within webinterfaces as they can only update the HOST Klipper but not the MCU Klipper.
In your case the above explanation might not be fully sufficient because your issue is caused by the unofficial Klipper modifications (see the -dirty indication in the log).
As I did not had this issue myself so far, I’m not 100% sure what the best approach is. You can try:
Approach 1:
  1. Revert all modifications coming from the Beacon, i.e. run a
    git reset --hard master --
    git pull
    in your Klipper folder
  2. Run make distclean && make menuconfig, build and flash a new firmware for all your MCUs, i.e. including EBBs, Linux Host MCU, CAN, etc.
  3. Apply the relevant modification for the beacon as per Beacon’s instructions
Approach 2:
    git pull
  2. Apply the relevant modification for the beacon as per Beacon’s instructions
  3. Run make distclean && make menuconfig, build and flash a new firmware for all your MCUs, i.e. including EBBs, Linux Host MCU, CAN, etc.
thank you…
I solved it another way…
On the Voron website they explain a method to make a Script that forces the update of the MCU.
I attach a link to the video in case it helps someone.
Voron method for update MCUs
