"mcu" unable to connect
Printer Model: RatRig Vcore 31
MCU / Printerboard: Octopus Pro + SHT42
klippy.log (345.4 KB)
I want to try to make the klipper configuration in 1 file, not in many as I have now.
For this I decided to start from scratch, reinstalling RatOs…
But the first one on the front, RatOs (a version of Mainsail with many Macros) does not find the MCU, when Rpi sees it via USB, and a few hours ago, Fluidd saw it…
Does anyone know why this could be?
Use the command:
ls /dev/serial/by-id/*
and replace the serial: ... with the correct output
i have sended
the console responds…
/dev/serial/by-id/usb-Klipper_stm32f429xx_3A0039000D50304738313820-if00
the correct line would be?
serial: /dev/usb-Klipper_stm32f429xx_3A0039000D50304738313820-if00
That “name” change would have been because the firmware it has installed is different from the one provided by RatRig. In the RatRig the name is changed…
I suposse…
As it is described here:
https://www.klipper3d.org/Installation.html#configuring-klipper
it needs the full path.
This is wrong. Just copy paste the exact console output from the command you ran.
