MCU unable to communicate
Printer Model: Modified RatRig V3.1
MCU / Printerboard: BTT Octopus
Host / SBC Linux PC
klippy.log (60.5 KB)
I have a PC running Linux Mint as an alternative to using a Raspberry Pi
I have the printer homing and was working on getting everything working correctly. I was tring to get a relay to via the fan out out on the Octopus board. While doing this I think I damaged the board because the MCU was no longer able to communicate.
I have replaced the BTT Octopus board and installed the firmware. I have not connected the relay to eliminate causing the problem again.
I am able to get the serial id. via the command prompt: ls /dev/serial/by-id
serial: /dev/serial/by-id/usb-Klipper_stm32f446xx_290029001850535556323420-if00
I have another PC that I loaded Linux onto. Installed klipper. I get the same problem. Unable to connect to MCU.
In the klipper log is see this
mcu ‘mcu’: Unable to open serial port: [Errno 2] could not open port /dev/serial/by-id/usb-Klipper_stm32f446xx_05001C001350535556323420-if00: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-Klipper_stm32f446xx_05001C001350535556323420-if00’
The Klipper_stm32f446xx_05001C001350535556323420-if00’ does not match the current ID. Klipper_stm32f446xx_290029001850535556323420-if00
I do not know why this information is in the log. Please know that I have not reviewed klipper logs much so the information is new to me.
I have read every post I can find but have not been able to find a solution. Any help would be greatly appreciated.
SOLVED!!!
When I copied and pasted the printer.cfg file to make a copy as a backup. I also copied and pasted the text into the printer.cfg file. Basically I had 2 cfg in the file. I never scrolled down far enough to see it. I deleted the duplicate cfg. now it works.
