Mcu 'mcu': Unable to open serial port
Printer Model: Ender 3 S1
MCU / Printerboard: Creality Slient Board 4.2.7
klippy.log (18.6 KB)
Describe your issue: After one failed print and a firmware reset, Klipper says it cant find/locate MCU. I swapped out the Board, USB Cable, and uninstall klipper/Mainsail.The error would lead me to the same error. I used the “ls /dev/serial/by-id/” while SSH and it says it couldnt identify a MCU.
Hello @FruitSamuraG !
Have you checked the serial ID?
Hello, I found the root of the problem. This is related to an OS update which holds the Debian bug. I have SSH into it and revert it back to V3.
