Klipper unable to connect to MCU after exhausting other support materials I could find
Printer Model: Ender 3 V3 SE
MCU / Printerboard: Stock
Host / SBC: Raspberry Pi 4b, Raspberry Pi OS debian 12 (bookworm) base
klippy.log (168.7 KB)
I have been trying to get klipper working using a firmware that enables use of the stock display but I have run into issues with the MCU not being able to connect as shown in my klippy.log and can’t work out why, as in my printer.cfg I have the serial listed as below in my mcu section:
restart_method: command
and I have also ensured that the serial thing is correct by using.
ls -l /dev/serial/by-id/
and correctly entering into my printer.cfg so I have no idea where this
mcu 'mcu': Unable to open serial port: [Errno 2] could not open port /dev/serial/by-id/<your-mcu-id>: [Errno 2] No such file or directory: '/dev/serial/by-id/<your-mcu-id>'
is coming from.
Any suggestions would be greatly appreciated
Just as a check, try dropping back to Debian 11 (bullseye)
Will do, I’ll update if it works.
Got it working by doing another fresh klipper install, don’t know why it didn’t work the first 3 times, but thanks.
