Just installed Klipper to Raspberry Pi 3B - all seemed to go well, obtained the MCU as
/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 however still getting the error message mcu ‘mcu’: Unable to connect after rebooting
Cheers, I’ve reflashed the board and got the same id /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 but same issue. I’ve attached the report you mentioned Sudo dmesg.txt (88.1 KB)
I thought it might have had to be a UART id as I have the ender3 v2 - also checked this and this came back as ttyAMA0
as I’m using the ender 3 v2, I believe the LCD screen won’t work with it, is there away of finding out if the board has been flashed as I have unplugged the screen? Thanks
oh ok , any other suggestions? on the report was it showing the board this time? do I need another USB cable ? just trying to find a resolution. Followed a tut on youtube using the same gear and everything worked for them, would it make a difference if I switch USB ports on the pi?
ii libmm-glib0:armhf 1.14.12-0.2 armhf D-Bus service for managing modems - shared libraries
ii modemmanager 1.14.12-0.2 armhf D-Bus service for managing modems
just thought while rebuilding the bin file. my pi is powered via the GPIO pins, would I have had to change something there ? also the baud are is set to 250000 is that correct ?
