After upgrade mcu Unable to connect
Printer Model: Voron 2.4r2
MCU / Printerboard: Octopus v1.1
So I have decided to upgrade to the voron tap, btt sb 2240 can bus with the U2C board. I did do an update thinking that I might need that with these extra mods being installed.
Since the update I am unable to connect to the mcu. After I flashed the octopus I can get connected until i reboot the printer. Also having troubles with a hand full of other things, but first thing is first. I have tried to re-flash my octopus through usb using CanBoot ( Katapult ) and as well as winscp with Micro sd card many times with no luck. I have re installed Klipper and Mainsial on my raspberry pi 4, I have gone through the trouble shooting and it seams its over my head. I feel like my issue is in this Printer.cfg area…
Very new to this, any help would be greatly appreciated.
serial: /tmp/klipper_host_mcu
Obtain definition by “ls -l /dev/serial/by-id/” then unplug to verify
serial: /dev/serial/by-id/usb-katapult_stm32f446xx_2B0040001750344D30353320-if00
restart_method: command
klippy (48).log (215.8 KB)
mcu 'mcu': Unable to open serial port: [Errno 2] could not open port /dev/serial/by-id/usb-katapult_stm32f446xx_2B0040001750344D30353320-if00: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-katapult_stm32f446xx_2B0040001750344D30353320-if00'
  • The error is pretty clear: there is no /dev/serial/by-id/usb-katapult_stm32f446xx_2B0040001750344D30353320-if00
  • Also since this serial contains katapult, it is a strong indication that you obtained it when the board was in bootloader mode
Reboot / Reset your board, then try again with ls -l /dev/serial/by-id/*
Thankyou sir for your time… Greatly appreciated.
