Need help with my sovol s07
Printer Model:
MCU / Printerboard:
…sovols07
it is not wanting to connect to the MCU While it was in the middle of a long print it stopped and said something about an update failing and to press firmware restart well i accidentally did reboot and it ended up stuck in the boot mode but i reflashed it and it was able to connect to the mcu and as soon as i started leveling it again it lost connection to the mcu ive looked everywhere for a solution. idk what to do. heres my klipper log
klippy (1).zip (11.2 KB)
mcu 'mcu': Unable to open serial port: [Errno 2] could not open port /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0'
The key part is No such file or directory: '/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0'
Apart from the worst case, a defect board, you will likely find your reason here: Issues flashing the printer board
