About the Knowledge Base category / Table of Contents
A collection of useful Klipper know-how and tips
Table of Content
General
Support
Common Klipper Error Messages
Miscellaneous Topics
Final Notes
  • The leading and official documentation is https://www.klipper3d.org/
  • This category will be amended or edited as topics and time permit.
  • This category is and will remain read-only for users. If you wish to discuss something, open a new post and link to the relevant content.
  • Suggestions for additional topics or changes are highly welcome. We will review them and make decisions accordingly.
  • The information in this category is released under the same license as Klipper: GPL v3.
  • The content is created by users for users. While every effort is made to provide accurate information, no liability is assumed whatsoever.
Calibration prints
Ls /dev/serial/by-id/* no longer works - WORKAROUND
Printer for 0.02 layer high?
Heat hot end while running bed_mesh_calibrate
Homing to -0.01
Modded Ender 3 Pro + CR Touch
Klipper not flashing or not connecting
M109 in start gcode not working?
"mcu" unable to connect
UPDATE error and I got the error message
How many can bus can you conect to rpi
Unknown commands and double bed meshing
"MCU 'mcu' shutdown: Timer too close" when homing
Unusual dual head printer - looking for advice
Btt SKR 3 EZ Bltouch not opperating
Turn webcam from Klipper
Dudes how configure "spreadCycle" vs "stealthChop" in extruder
Second MCU address for temp sensor
Fine tuning extruder steppersetup
Canboard.... my war
SET_VELOCITY_LIMIT for Z-axis on Cartesian
I don't know how to git the address of my muc pi?
CR-Touch Help - hiting bed hard
Bl-touch, probe calibrate, and fine adjustments aren't working? IDK, I am stupid. Sorry
Installing Klipper with KIAUH
Klipper has encountered an error
How-to prevent bed drop during config save restart (Z Belted printer)
Yet another mcu 'mcu': Unable to connect Ender 3 pro
What does this error message mean?
Having some trouble with variables
Move out of range: 37.259 -49.197 1.000 [0.000]
Klipper delta bed mesh/ z height issues
Cap. Sensor, Inductive Sensor, and Missed mm due to Risers
Canboard 2 firmwares?
Doubts create dirs and cfg files in Fluidd
Nozzle Scoring Print Bed
Klipper configuration file not located in 'config' folder
Pwm_cycle_time causes random heater_bed error
Help with sensorless homing and pinda probe
Could it be a blank space in the PIN name?
Extruder not hot enough
BTT Manta M8P Pi fan
Probe virtual endstop only useful as endstop pin
Priority of [include....]
Doubt about print limits
Defining the position of a dockable probe on a Delta printer
Unable to extract params from: query_thermocouple - PT100 CANBUS EBB42
Printing on the Same Line Height/Z-Axis Issues
Speed and Lift_Speed Calculations for T8 Leadscrew
USB port changes
Stuck in boot loop after update
Two Z endstops plus probe with an IDEX printer
New sprite kit causing printer restart
Help with Fluidd
Bug? Danged If I Know
Pid_calibrate interrupted
Web Browser tab names
Save Zoffset between print jobs
Update Octopuus Pro 429
Endstop y still triggered after retract - Ender3 V2 with BLTouch
Pressure advance in multihead
To help any flsun super racer users
How to get the Controller fan to turn on at power up?
LDM slicer? Anyone know of one?
Missing configuration
How can I force an out of range movement?
Z lifts on decreasing y motion when printing brim
Oids already allocated
How the important its define UART pin in CFG?
System history restore
Closed printer not extruding
My rpi host can't connect to Klipper
Extruder selection button in Mainsail
Cancel Print followed by G28 fails
Getting Two Z_axes and one Endstop w/out Four Wires?
Several errors causing Lost communication with MCU 'mcu'
Timer too close, trying to understand log files
Unable to connect to MCU after update
Controlling two "fans" for cooling
CANBus_Query.py not returning EBB36's UUID. Setup: Pi 4, Octopus v1.1, EBB36 v1.2
Probe_Calibrate does not function correctly or within a normal range?
Mcu 'mcu': Unable to connect after emergency stop
Template syntax error
Ender 3 V2 Neo with Sprite Pro printer.cfg
Getting skips in my extruders if extruding 1 color through a mixing hotend
After update i cant connect
Trouble installing klipper on a Ender 6
Start print homing after tall print - is this a bug?
Z height changed after QUAD_GANTRY_LEVEL
Moonraker not connected to klipper
Temperature log
Ender 6 Triple Z tile moves in the wrong direction but Z Home is correct on all 3 steppers
Doubts in Ztilt and Bed Mesh
Tmc2209 current
Option 'pin' is not valid in section 'heater_bed'
It is not possible to cancel printing immediately after the start, until the heating occurs!
How set Save_config_pending_items to {} in a macro?
