Speed and Lift_Speed Calculations for T8 Leadscrew
Printer Model: Makeshift PrintrBot 1403
MCU / Printerboard: A64/STM Recore
klippy.log : klippy.log - Pastebin.com is my klippy.log
Hello,
I have a cartesian printer w/ a new T8 leadscrew. I calculated, via the docs, to have a rotation_distance of 8 for my T8 leadscrew. Thank you…it is working but my gantry that is attached to the Z_Axis refuses to move.
I can manually, w/ drill, move my gantry up, down, and back along w/ XY planes that I can move by hand via their slide rods and belts.
Anyway…I am trying to calculate speed for my gantry and lift_speed also.
  1. My motors are 200 Revolution motors w/ 1.8 degrees.
  2. All motors are alike except for Y. It is an Ocean motor that is different, same mfg, than the two other motors for Z and X.
Calibrations still need to take place but first, I need to home this machine and move the Z_axis Gantry.
Seth
P.S. If you have time to read and you understand what I am trying to conquer here, please advise me.
You always have to home first, so that the printer knows the where to stop and where the print head is.
Right… @EddyMI3D ,
I cannot home yet due to some error that I do not understand yet. The motor is quiet but does not move the Z_axis to home the machine. It is stalling and pausing.
I think it has to do w/ the speed, lift_speed, and overall Z_axis config. I have not configured things correctly b/c of this homing issue and my config. so far.
Seth
Post a complete klippy.log
And please here. Not everyone can do pastebin.
You got it. @Sineos …I will post the whole log.
Seth
@EddyMI3D , I am sorry. I went to the maximum line limit w/ klippy.log.
Klipp.log.txt (47.9 KB)
You can zip a huge file.
Also you have been asked to share the file, not it’s contents.
I am replying to my own thread. I am not sure of it currently but…
  1. I think it is friction as the cause.
  2. I have not singled out anything.
  3. The motor is working but stuck on something.
If you guys want, we can close this issue.
I really think it is a friction issue so far unless you see otherwise.
Seth
P.S. Sorry to bother your #general-discussion part of the forums. It is a faulty leadscrew. They decided to sell a bent one to me.
Excuse me…
