Printer Model: voron 2.4
MCU / Printerboard:
When pasting code or config snippets use the code tags </> in the menu above
HI, I now use Klicky instead of the original proximity switch, so in the configuration homing_override replaces the original safe_z_home. Now I don’t know how to modify the Z-axis boost speed during homing.Because when my printer executes G28, there is resonance when raising or lowering the gantry. I modified the descending speed in stepper_z and the resonance disappeared, but I can’t modify the ascending speed now because I don’t know where to modify it.
