A strange problem when homing Z
Printer Model: Voron2.4
MCU / Printerboard:monster8
klippy.log (2.0 MB)
Describe your issue:It‘s a strange thing that,I turn off the V2.4 for few days,when I turn it on today,back to zero is normal.But when I start to print,Gcode G28,Z axis should go down to touch the bed,they rise 10cm or decline a little(no touch),and an error message is displayed:No trigger on z after full movement.What is problem?
it might have something wrong with my tap wire
Run QUERY_PROBE to see if the Tap is working properly. If it’s triggered, then you likely have a wiring issue.
