Printer Model: RATRIG MINION
MCU / Printerboard:BBT SKR 2
klippy.log.2023-05-03.txt (1.7 KB)
“Moonraker can’t connect to Klipper!”
“Please check if the Klipper service is running and klippy_uds_address is correctly configured in the moonraker.conf.”
Can’t connect to printer mcu after I updated. Seems to be a uart connection issue? Can’t figure it out. Thank you.
