Moonraker cannot connect to Klipper
Printer Model: Proforge 4
MCU / Printerboard: BTT PI + Octopus MAX EZ
I accidentally hit the klipper update today and keep losing moonraker connection to klipper. klipper versionv0.12.0-452-g75a10bfc
the moonraker log file:
moonraker (5).log (25.9 KB)
i have reflash the PI for a few times to solve this error, but still keep occuring, is there any methods to deal with it without reflashing the PI board. My great thx if anyone can help me solve this urgent problem!
With what have you flashed the PI’s SD card?
Im using a BTT PI, the seller provides a old version image of klipper and ask us to update to the latest version of Klippers on mainsail
Ewald via Klipper <notifications@klipper.discoursemail.com>于2025年3月5日 周三20:19写道:
The issue is most likely caused by version incompatibility or outdated configuration files. First, back up the existing configuration files, then refer to the official documentation for Klipper and Moonraker to check and update the parameters in the configuration files.
Thanks a lot to ur suggestions. According to the moonraker documentation I have double checked the config earlier yesterday, and it looks nothing wrong. I found some comments, uninstalled the moonraker and reload it with ssh, which also not working for me. And I found today the connection error sometimes occurs after clearing of klipper or moonraker .log with mainsail, but I cannot see any correspondence between these things.
jimmychou via Klipper <notifications@klipper.discoursemail.com>于2025年3月6日 周四12:55写道:
backup your config folder in printer_data with WinSCP or similar, install the lastest release in btt github, then update all and import your files contained in your backup in the new config folder, except the moonraker.conf
