Moonraker не может подключиться к Klipper!__Moonraker can't connect to Klipper!
FLsun t1 pro
MCU / Printerboard: Pi
Host / SBC mansail klipper
After an unsuccessful update of the brains on which there was no printer serial number, files disappeared and there is no connection to the server, what is it and what files have disappeared and where to look for them again??
logs-20260503-144136.zip (1.7 MB)
What files were there and where to look for them?
except for the ones in the image
Exactly what did you update. What method did you use, Mainsail, kiauh, or a update package from FLsun?
Can you access the Pi over SSH?
Flsun T1 pro
Pi connection yes
Ssh connection yes
Is your touchscreen useable? If so try to do an OTA firmware reset.
The upgrade package you linked only has new/updated files and brute-force overwrites over the existing installation. It is likely you can never get back to where you started.
See also:
