Mainsail Klippy-state: error
I have three problems as follows :
*mcu ‘mcu’: Unable to connect
Error configuring printer
*printer is not ready
*Unparsed config option ‘type: web’ detected in section [update_manager]. This may be an option no longer available or could be the result of a module that failed to load. In the future this will result in a startup error.
*** attached below the moonraker log
moonraker (1).log (149.0 KB)
In moonraker.conf change
[update_manager]
refresh_interval = 168
type = web
repo = mainsail-crew/mainsail
path = ~/mainsail
to
[update_manager mainsail]
type = web
path = ~/mainsail
and post your klippy.log file
still need some help to make the printer ready
http://paste.c-net.org/MadamBunny
Most likely your board is not correctly flashed.
Carefully work through Installation - Klipper documentation and also check the instructions on top of your respective cfg from here: klipper/config at master · Klipper3d/klipper · GitHub
I’m sure that … I’m having an issue with flashing klipper.bin using SD card
do u know any way to flash it using … ssh … the printer is serial connected
i have tried once a method earlier via ssh but i can’t remember it any more
Well, since you did not even provide what type of board you are using, it is hard to give any advice.
Following above instructions and especially using the correct options for make menuconfig according to your board, are usually working if done correctly.
