I am trying to install Klipper with kaiuh and I’m not sure where I’ve gone wrong. after installing everything I’m trying to go login to mainsail only to be met with a unable to connect to moonraker sign. I’ve trying to see if Moonraker is active on Putty and it keeps saying is activating. I’ve tried some different scripts I found online off the Moonraker site and nothing seems to help, I’ve even tried re-installing just Moonrker and nothing. I’m using a Raspberry Pi 3 and I don’t have any idea what I’m doing if there’s anyone who can help I’d greatly appreciate it
Hello @Kadukong !
Did you follow a certain guide?
Hello I was watching the YouTube guide from this guy
https://youtu.be/h99vGPACB8M?si=sRoVNLB05Y07jPJc
Maybe you should try the genuine one:
Do you think I should restart my entire installation process? Format sd card and everything? And when it’s asking me to use v6 of kiauh should I opt out of it??
hey thank you so much for your help I think didn’t format my SD card properly cause I ran into the same problem but then I did the long format process and reinstalled and it worked. it also definitely might have been that I didn’t install the lite version of the Pi OS. anyway, I got mainsail working for now and I very much appreciate your advice. if I run into any other issues would it be ok for me to message you again? either way, thank you
hey, I’m sorry to bother you again I am not a huge fan of talking to millions of people online with my problems just to be ridiculed for and my question not get answered. I’m running into another problem trying to set up my printer so I’ve gotten my firmware updated and I’ve copied over the mcu ID but now it’s giving me an error for a pin. I copied the configuration file right from their database and I’ve checked the pinout of the board which is correct. I don’t know I’m lost if you can help I would appreciate it. I’m running a pi3 and mks gen l the error coming up is Pin ‘P0.24’ is not a valid pin name on mcu 'mcu
the configuration I have is. also on another note I’m running tmc 2208 but in its normal mode should I change it on my configuration or leave the stock settings?
This file contains common pin mappings for the MKS SGEN_L board. To
use this config, the firmware should be compiled for the LPC1768.
See docs/Config_Reference.md for a description of parameters.
[stepper_x]
step_pin: P2.2
dir_pin: !P2.3
enable_pin: !P2.1
rotation_distance: 40
endstop_pin: ^P1.29 # ^P1.28 for X-max
position_endstop: 0
position_max: 320
homing_speed: 50
[stepper_y]
step_pin: P0.19
dir_pin: !P0.20
enable_pin: !P2.8
endstop_pin: ^P1.27 # ^P1.26 for Y-max
position_endstop: 0
position_max: 300
homing_speed: 50
step_pin: P0.22
dir_pin: P2.11
enable_pin: !P0.21
rotation_distance: 8
endstop_pin: ^P1.25 # ^P1.24 for Z-max
position_endstop: 0.5
position_max: 400
step_pin: P2.13
dir_pin: !P0.11
enable_pin: !P2.12
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: P2.7
sensor_pin: P0.23
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 260
#[extruder1]
#step_pin: P0.1
#dir_pin: P0.0
#enable_pin: !P0.10
#heater_pin: P2.6
#sensor_pin: P0.25
[heater_bed]
heater_pin: P2.5
sensor_pin: P0.24
control: watermark
min_temp: 0
max_temp: 130
[fan]
pin: P2.4
serial: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
[printer]
kinematics: cartesian
max_velocity: 200
max_accel: 2000
max_z_velocity: 25
max_z_accel: 100
Either upload your config as a file:
Or at least use the Preformatted Text feature of the editor.
Just copy&pasting code leaves quite a mess behind.
I tried uploading the file and nothing changed it’s still giving me the same error.
https://raw.githubusercontent.com/Klipper3d/klipper/refs/heads/master/config/generic-mks-sgenl.cfg
This is a link to the .cfg file. I’m stumped on this one. I’m also not sure what u meant by trying a preformatted test I thought it was already in that way or what software u have displayed there like I said in a novice. if u have any other ideas let me know I appreciate it
Hi Kadukong,
EddyMI3D was saying that you should use the formatting buttons at the top of the edit window on the left, to make text (not test) more readable for people trying to help you. You should always keep an eye on the preview window on the right so you can see how it will appear to other users trying to help. No one wants extremely large text intruding especially when it has no significance. To help you see both windows, you can drag the separator bar up the screen as needed. You can drag it down again at any time if it is obscuring something else to wanted to refer to.
I think that unless you have solved your new problem yourself, you will also need to create a new post preferably in “General discussion”. Once a problem has been marked as solved, it is usually ignored unless there is some relevance to other problems. Please use the “General Discussion” to restate your problem as it requires you to provide all the information needed to help others to help you. eg.
Printer Model: Anycubic Kobra Neo
MCU / Printerboard: [stock] HC32F460 / TriGorilla Gen V3.0.6
Host / SBC: Pi 5 2 GB
klippy.log (1.8 MB)
Or whatever is relevant to your setup. The klippy.log is especially important as it contains your generic-mks-sgenl.cfg as read by Klippy, not what YOU think your config MAY BE.
If you think it is relevant, you can also link back to your original topic (request) by opening it is a new tab/window, selecting the URL and using the hyperlink tool at the top of the edit window, or pressing Ctrl+K.
Good luck.
