I am running Klipper on a CR6-SE which uses a nozzle probe much like the Voron Tap. But the trigger is via a strain gauge. I am running adaptive bed meshing for each print.
In my start code I have it ;
- Heat the bed (Per the Slicer)
- Set the hot end to 150c and wait
- Run bed_mesh_calibrate
The bed maintains the temp requested but as soon at "bed_mesh_calibrate " is executed my hot end heater turns off. How to I keep the hot end on during the probing cycle?
G1 X{x_wait} Y{y_wait} Z15 F9000 # Goes to center of the bed
M190 S{target_bed} # Sets the target temp for the bed
SET_DISPLAY_TEXT MSG="Heatsoak 5 min" # Displays info
G4 P300000 # Waits 5 min for the bedtemp to stabilize 9Min x 60000 = Mil Sec)
# Heating nozzle to 150 degrees. This helps with getting a correct Z-home
SET_DISPLAY_TEXT MSG="Hotend: 150c" # Displays info
M109 S150 # Heats the nozzle to 150c
SET_DISPLAY_TEXT MSG="Bed mesh" # Displays info
#STATUS_MESHING # Sets SB-leds to bed mesh-mode
bed_mesh_calibrate # Starts bed mesh
# Heats up the nozzle up to target via data from slicer
SET_DISPLAY_TEXT MSG="Hotend: {target_extruder}c" # Displays info
# STATUS_HEATING # Sets SB-leds to heating-mode
M107 # Turns off partcooling fan
M109 S{target_extruder} # Heats the nozzle to printing temp
M104 S{target_extruder} #Waits for nozzle to reach temperature defined in
slicer
adaptive_purge #add adaptive purge
Printer Model: CR6-SE
MCU / Printerboard: Creality V 1.0.0.3
CRSE-2 log klippy.log (4.5 MB)
