Printer Model: Vcore 3.1
MCU / Printerboard: Octopus Pro+EBB42
klippy.log Not necessary
I’ve had some problem, I think with the extruder motor overheating, and one of the things I want to check is if the driver (TMC2206) is configured correctly.
Right now I have this configuration for the extruder driver
[tmc2209 extruder]
uart_pin: EBBCan: PA15
run_current: 0.60 # antes 0,40
stealthchop_threshold: 0
interpolate: True
sense_resistor: 0.11
driver_TBL: 0
driver_TOFF: 4
driver_HEND: 6
driver_HSTRT: 7
I have read that for the extruder motor it is advisable to put it in “spreadCycle” mode, but I am not sure how to do that if:
A)-Setting it to 0, just as I have it (stealthchop_threshold: 0)
either
B)- Erasing the line (stealthchop_threshold: 0)
C)-A nother way…
The truth is that the lines: driver_XXXX, I don’t know where they are from, I think I remember that I copied them from some configuration… They are fine, it has the Orbiter 2 motor, I think a Nema 14 LDO
Are ok?
Thx
