Ls /dev/serial/by-id/* no longer works - WORKAROUND
Printer Model: Formbot Raptor 2
MCU / Printerboard: Vivedino 1.1 (mega2560 mcu)
after a couple of days off, my working klipper installation on pi400 couldnt find the printer.
Command ls /dev/serial/by-id/*
Output ls: cannot access ‘/dev/serial/by-id/*’: No such file or directory.
find a post (E3V2 / 'ls /dev/serial/by-id/*' not working - #11 by HD4K)
that workaround was the solution. I dont know what happens, put here for reference.
Regards
Rick
Youre fast! the reply cames before my edit
Workaround for reference added to the tittle.
Many thanks for the answer!
Regards
Rick
hi,
I think I’m affected by this bug…
I have tried the solution, but it still doesn’t work.
When editing the file with the sources… is this content correct?
deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
deb http://ftp.debian.org/debian bullseye-backports main non-free contrib
I think yes, keys are ok? as per post
Solved… another user pass me a Script that solved de issues in Fluidd
Thx
@Peurif care to share the script? :slight_smile: Thx!
