I can't get "ls /dev/serial/by-id/*" to work
Printer Model: Voron V0
MCU / Printerboard: BTT SKR 3 EZ
klippy.log (11.5 KB)
I got a new BTT SKR 3 EZ board & am installing it on my Voron V0.2. I have followed the details for installation & I can log into Mainsail via web browser with the IP address. There is a button on the SKR board for USB or CAN & I have that set to USB (up)
I have not set up the Printer.cfg file yet as I cannot get the serial port for the MCU.
SKR 3 board is powered by 24V supply & no other cables are connected to it yet.
ls /dev/serial/by-id/* reports back ls: cannot access ‘/dev/serial/by-id/*’: No such file or directory
I found this Debian 11 (Bullseye) udev bug - No board or serial found & it turned out I had that version. It looks like the update worked & now I have:
udev:
Installed: 252.5-2~bpo11+1
Candidate: 252.5-2~bpo11+1
Version table:
*** 252.5-2~bpo11+1 100
100 Index of /debian bullseye-backports/main armhf Packages
100 /var/lib/dpkg/status
247.3-7+rpi1+deb11u2 500
500 Index of /raspbian bullseye/main armhf Packages
Unfortunately the ls /dev/serial/by-id/* command still shows “ls: cannot access ‘/dev/serial/by-id/*’: No such file or directory”
I also tried
Unplug USB
Re-plug USB
sudo dmesg
Which returned a lot of info. The only USB parts I could find are:
[ 1.570447] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 6.01
[ 1.571326] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.572166] usb usb1: Product: xHCI Host Controller
[ 1.573018] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.573843] usb usb1: SerialNumber: 0000:01:00.0
[ 1.575371] hub 1-0:1.0: USB hub found
[ 1.576248] hub 1-0:1.0: 1 port detected
[ 1.578084] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc dDevice= 6.01
[ 1.578884] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.579653] usb usb2: Product: xHCI Host Controller
[ 1.580424] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.581219] usb usb2: SerialNumber: 0000:01:00.0
This looks like the USB hub on the Pi & not the BTT SKR 3 EZ board
However when I plug in the Klipper expander board into the Pi I get this at the bottom of the list:
[ 1695.021745] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 1695.128943] usb 1-1.3: New USB device found, idVendor=1d50, idProduct=606f, bcdDevice= 0.00
[ 1695.128977] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1695.128991] usb 1-1.3: Product: budgetcan gs_usb
[ 1695.129004] usb 1-1.3: Manufacturer: budgetcan
[ 1695.129015] usb 1-1.3: SerialNumber: 002A004C5542501720303939
[ 1695.299394] CAN device driver interface
[ 1695.304686] gs_usb 1-1.3:1.0: Configuring for 1 interfaces
[ 1695.306854] usbcore: registered new interface driver gs_usb
[ 1695.468607] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
Any suggestions?
If you are using the Klipper CAN bridge in the firmware on the SKR3 then it will not show as a serial device /dev/serial/by-id, it will now only show as a CAN bus device.
