Klipper
Debian Bullseye Bug causing Klipper to no longer find the printer board
Announcements
Sineos
May 5, 2023, 6:49pm
1
Moved to
Debian 11 (Bullseye) udev bug - No board or serial found
Raspi 4 failing to make usb connection to MCU
Klipper not connecting to the MCU
Klippy not connected? after updates
Debian bug on Pi Model B+
Cannot get Klipper to connect to my new Kingroon KP5L
Ls /dev/serial/by-id/* no longer works - WORKAROUND
Klipper not connecting to printer
Debian Bullseye Bug Remedy Script
Can´t run ls /dev/serial/by-id/*
Unable to connect to MCU after update
Mcu not found while using kiauh on skr 1.4 turbo
Voron 2.4 No Mcu Found
Error with klipper connecting to moonraker
MCU problems installing klipper on S1 pro
MCU : Unable to connect
Can't start a Linux host mcu on Orangepi zero 3
'EBBCan': Unable to connect - After FW updates
MCU _problem_ cannot access '/dev/by-id/'
Klipper cant connect to mcu
Unable to Print GCode files
SKR3 EZ - No MCU serial
Problems Implementing Debian Fix
Ender 3 V2 - MCU cannot be found
Random Error During Print "Can not update MCU 'mcu' config as it is shutdown"
Ender 3 V2 not connecting
Mcu 'mcu': Unable to connect after emergency stop
CANBus_Query.py not returning EBB36's UUID. Setup: Pi 4, Octopus v1.1, EBB36 v1.2
Newbie- can't flash klipper on octopus for voron 2.4
Sineos
May 10, 2023, 8:09am
5
Moved to
'mcu': Unable to open serial port
After update i cant connect
Kingroon KLP1 Error mcu 'MKS_THR': Unable to connect
Related topics
Topic
Replies
Views
Activity
General Discussion
6
10179
August 16, 2023
General Discussion
19
2876
August 31, 2023
Solution: "MCU connection error" since at least April 30th due to Debian 11 update
General Discussion
2
1801
August 25, 2023
General Discussion
20
1652
May 13, 2023
General Discussion
6
1285
June 11, 2023
