Timeout with MCU / Lost communication with MCU
Timeout with MCU / Lost Communication with MCU
Background
This error occurs when the Klipper host receives no response from a connected MCU to its regular “heartbeat” or other command messages for several seconds.
It often appears in conjunction with the Got EOF when reading from device error.
:warning: Important:
Klipper only detects the symptom - a communication loss. It is not capable of determining the root cause, which may lie outside of Klipper’s control (e.g., hardware faults, power issues, electrical noise, or environmental instability).
Causes and Potential Solutions
The klippy.log will mostly contain the fact that this issue occurred but cannot offer a direct pointer to the cause. Carefully analyzing and working through the points listed below is needed to pinpoint it.
  • Unreliable connection between host and MCU
    Inspect all cables and connectors. Any loose, poorly crimped, or damaged connections - anywhere in the printer - can intermittently fail or cause shorts that crash the MCU. This is a common issue, and the damage can be well-hidden and difficult to detect.
  • Inadequate or overloaded power supply
    Ensure both the host and the printer’s main system use high-quality, appropriately rated power supplies.
    If the error occurs during high-power operations (e.g. heating bed and hotend), try lowering temperatures. If the issue disappears, the power supply is likely undersized.
  • Incorrect power setup
    Avoid powering the printer board via USB instead of the main supply, or simultaneously via both. Such configurations can lead to unstable voltage conditions or ground loops.
  • Faulty or unstable USB port on the host SBC
    Some SBCs (like Raspberry Pi models) have known USB quirks. Try different USB ports, switch between USB2 and USB3 ports (if applicable), or use an external powered USB hub.
    If you are already using an external powered USB hub, try removing it. Some models do not work well with certain host computers.
  • Low-quality or unsuitable USB cable
    Use a short, shielded, good-quality USB cable. Avoid data-only or charging cables that lack proper shielding or data lines.
  • USB bandwidth saturation or conflict
    Disconnect other USB devices (e.g. webcams) that may be competing for bandwidth or causing power issues on the USB bus.
  • Improper grounding or power domain isolation
    Grounding issues can cause subtle or intermittent failures. Avoid ground loops, and do not float grounds unintentionally.
    If grounding concerns are suspected, professional advice should be sought, as improper grounding is both a stability and safety issue.
  • ElectroMagnetic Interference (EMI)
    EMI from stepper motors, heaters, or fans can interfere with USB or MCU stability. Ensure proper cable shielding, grounding, and avoid running signal wires near current-carrying lines.
  • ElectroStatic Discharge (ESD)
    Moving plastic parts - such as belts, filament, or spools - can build up significant static charge, especially in dry environments. This accumulated energy can discharge into nearby electronics, potentially causing the MCU to reset or disrupting USB communication.
    Proper grounding of all metal components (e.g., stepper motor casings, frame) and shielding can help mitigate ESD effects.
Lost MCU connection
Random MCU communication errors
Is CB1 from BTT enough? Lost connection to MCU
Print stops mid print
Unable to Obtain MCU-Linux
Communication timeout during
Consistent failure at 50% print - MCU timeout
Possible SKR mini E3 V3 Failure Unable to communicate with MCU
Klipper sometimes doesn't connect to mcu error:-32601
Lost MCU communication
Several errors causing Lost communication with MCU 'mcu'
Ender 3: Lost communication with MCU 'mcu'
Mcu lost connection after start printing
MCU lost communication: I'm stumped
Lost communication with MCU 'mcu' again
Klipper restart : 'Got EOF when reading from device'
Printers stop During long prints/ Loses connection
Printer shuts down very early in to print
Lost communication with MCU 'mcu' Ender NG Build
I need to hire a professional to work on persistant MCU errors
Mainsail/klipper is stalling/pausing during printing
Help printer automatically disconnects after 3 seconds of linking
Klipper shutdown due to MCU communication error
System load issue?
MCU Randomly Loosing Connection on SKR 1.4 with BTT Pi 1.2
Lost connection to mcu ender 5
Sudden MCU Shutdown During Print
SV06 - MCU Shutdown - Can Someone Please Look At This Log?
Improved MCU connection error messages
MCU shutdown and prints fail
Internal error on command:"G3" / MCU connection lost
Manta M5P MCU lost
Voron 2.4 CanBus: Lost Communication to mcu (EBB36)
Lost communication with MCU FYSETC Voron 0
MCU Disconnect after first/second layer
"Lost communication with MCU" with no obvious reason
Mcu randomly disconnects mid print :(
CR-M4 imidiately stops after heating extruder after successful print
BIQU MicroProbe V2.0 not working
MCU Disconnected
Catalyst 3.0: MCU
Interrupted print with no error message
Klipper Internal error on command:"G1"
My Ender 3 V2 with CR-Touch Klipper config Issues
Printers Constantly Crashing Lost communication with MCU 'mcu'
Timeout with MCU 'mcu' Ender 3 v2 Mainsail
MCU keeps disconnecting +MCU.py errors
Sudden communication failure
Lost communication with MCU mcu
Ender 3 SE "Lost connection with MCU" Sonic Pad AND BTT Pad 7
Can a failing MCU cause 'bytes_retransmit'
Ender 3 V3 SE Printers Stop Communicating
Random MCU disconnects driving me crazy
Klipper shutting down mid print
Connection loss and lost
ANOTHER MCU Shutdown Mid Print - No Explanation
Klipper shuts down mid-print
CANbus error only when printing - EBB rp2040 sb2209
Printer shuts down after starting a print
Printer Stops Randomly Mid-Print
Lost communication with MCU 'btt_lis2dw
Printer keeps crashing Mid-Print
Internal error in MCU 'mcu' stepcompress and lost connection with MMB
MCU 'mcu' shutdown: Move queue overflow
Bytes_retransmit and Timeout with MCU
My printer stopped middle of print, randomly
Klipper Starts up and then gives error 'MCU 'mcu' shutdown: Invalid oid type'
Spontaneus stop during the print
Lost Communication with the MCU 'EBB42-1'
Lost communications with MCU
Help fixing "Timer too close" shutdown
USB CAN Bridge MCU cant connect but everything else on can bus Is fine
Ender3 S1 very frequent shutdown error
MCU randomly disconnecting
Bed Temp Fails to Hold Temperature
MCU communication keeps getting lost
Difficulty understanding source of error
MCU connection loss during print, USB connection issues
Random Firmware Restarts
Help: Klipper crashes mid-print
Error after Klipper firmware 0.13 update
Printer getting error and doesn't even start printing
MCU shutdown after couple hours
About the Knowledge Base category / Table of Contents
Klipper shutdown: Lost communication with MCH nhk
ADXL345 Stops working after being connected for a few seconds
Another one! Heater extruder not heating at expected rate
Hotend heating without control
TEST_RESONANCES AXIS=X Lost communication with MCU 'pico'
Klipper shutdown mid-print randomly
Klipper disconnected after printing 2+ hrs :(?
Internal error on G1" stepcompress error
FIRMWARE_RESTART always fails
Unhandled exception during run
Klipper seems to crash before print. First time installed today
Printer freaks out suddenly during normal print
Lost communication with MCU and MCU 'mcu' shutdown: Timer too close
Random: Timeout with MCU 'mcu'
Constantly getting slippy_shutdowns
