Lost MCU connection
Printer Model: Chiron
MCU / Printerboard:SKR3
klippy.zip (2.2 MB)
Hi, I’ve had a problem for sometrime now with my printer that is very frustrating. Prints will stop after sometime anywhere from 2hrs to 5hrs with an MCU communication error.
Things I’ve tried.
Replace USB cable
Isolate positive and negative of USB
Anyone got any other ideas?
I’ve tried all of these Timeout with MCU / Lost communication with MCU
Just pull jumper “VUSB”
Have you tried other USB connectors on your SBC?
You may have a look here Tronxy x5sa-2e V10 F446 board not staying connected - #7 by hcet14 and ask @KazWahs if it solved his issues.
Good luck, hcet14
I disabled my auto shutdown and left the printer running idle. And noticed after sometime I got this message. Does this just mean that it lost connection with my printer board “MCU”
Can not update MCU ‘mcu’ config as it is shutdown
Error configuring printer
And in the the log is the below repeated over and over again.
Args: [‘/home/pi/klipper/klippy/klippy.py’, ‘/home/pi/klipper_config/printer.cfg’, ‘-l’, ‘/home/pi/klipper_logs/klippy.log’, ‘-a’, ‘/tmp/klippy_uds’]
Git version: ‘v0.11.0-148-g52f4e20c’
CPU: 4 core ARMv7 Processor rev 3 (v7l)
Python: ‘3.7.3 (default, Jan 22 2021, 20:04:44) \n[GCC 8.3.0]’
webhooks client 3044842544: {‘program’: ‘Moonraker’, ‘version’: ‘v0.8.0-29-g80920dd’}
=============== Log rollover at Sat Mar 25 00:00:00 2023 ===============
mcu ‘mcu’: got {‘oid’: 16, ‘next_clock’: 132878336, ‘value’: 31382, ‘#name’: ‘analog_in_state’, ‘#sent_time’: 21434.888771075, ‘#receive_time’: 21435.433375186}
mcu ‘mcu’: got {‘oid’: 18, ‘next_clock’: 140878336, ‘value’: 6249, ‘#name’: ‘analog_in_state’, ‘#sent_time’: 21434.888771075, ‘#receive_time’: 21435.453361242}
mcu ‘mcu’: got {‘oid’: 16, ‘next_clock’: 252878336, ‘value’: 31382, ‘#name’: ‘analog_in_state’, ‘#sent_time’: 21434.888771075, ‘#receive_time’: 21435.733383519}
mcu ‘mcu’: got {‘oid’: 18, ‘next_clock’: 260878336, ‘value’: 6250, ‘#name’: ‘analog_in_state’, ‘#sent_time’: 21434.888771075, ‘#receive_time’: 21435.753352056}
mcu ‘mcu’: got {‘oid’: 16, ‘next_clock’: 372878336, ‘value’: 31380, ‘#name’: ‘analog_in_state’, ‘#sent_time’: 21435.873163538, ‘#receive_time’: 21436.033385945}
mcu ‘mcu’: got {‘oid’: 18, ‘next_clock’: 380878336, ‘value’: 6250, ‘#name’: ‘analog_in_state’, ‘#sent_time’: 21435.873163538, ‘#receive_time’: 21436.053398797}
mcu ‘mcu’: got {‘oid’: 16, ‘next_clock’: 492878336, ‘value’: 31381, ‘#name’: ‘analog_in_state’, ‘#sent_time’: 21435.873163538, ‘#receive_time’: 21436.333396371}
mcu ‘mcu’: got {‘oid’: 18, ‘next_clock’: 500878336, ‘value’: 6248, ‘#name’: ‘analog_in_state’, ‘#sent_time’: 21435.873163538, ‘#receive_time’: 21436.35341276}
