Printer Model: voron 0.2 Pro R1 from a Fysetc kit
MCU / Printerboard: Catalyst v1.0 with v0 Head Hub klippy (1).log (369.0 KB)
The printer was working in this setup for 100h, then i started it with the Head Hub unplugged. As i got a an error (ADC out of range) i plugged it in.
Since then i get the following error message and im no longer ably to ssh into the printer:
According to Timeout with MCU / Lost communication with MCU it may be missing power or bad connection.
The LEDs for 24V, and at the step downs of 5V and 3.3V are on.
Behaviour does not change when started without the head hub connected.
how can i go on with debugging? I’m a hardcore duet user taking my first steps into the klipper world.
There is a USB C right next to the mcu. Any ways to diagnose it via this port?
How to interpet these logs? I cant ssh into my pi to follow this procedure from
klipper3d . org → extracting-information-from-the-klippylog-file (and i cant paste the link?!)
Why?
hmm, being dumb is maybe the most approriate answer xD had the printhead out for maintenance and wanted to rush wifi setup. It stated an error (i guess “adc out of range” as it missed its hotend thermistor. So i quickly connected it.
