Cannot find MCU?
Printer Model: Ender 3
MCU / Printerboard: SKR3 V2 BTT
klippy (2).log (100.0 KB)
I already have a printer running klipper now excellently, so i wanted to upgrade my other printer to it as well.
I have a PI 4B flashed with mainsail and connected how ever the MCU to the board doesn’t work. I thought i fried the motherboard some how so i bought another one and its doing exactly the same.
I’ve got the same firmware i flashed my other printer with on a sd card inserted into the motherboard (both btt skr3 v2) so my logic is that if it worked on the other motherboard it should work on this?? its on the SD card as firmware.bin.
when I run ls /dev/serial/by-id/* to get my MCU i get back /dev/serial/by-id/usb-LeafLabs_Maple-if00 which i have in my printer.cfg.
I have no idea what else to do? any suggestions or help would be great!
Thank you
Klipper reports: ERROR
mcu ‘mcu’: Unable to connect
Error configuring printer
Also worth mentioning, the mother board isnt yet installed in the 3d printer, that and the Pi are sitting on my desk connect to each other, does that matter?
Are those printers the same and do they have the same printer board?
Same printers, same boards.
This indicates that Klipper is not correctly flashed on the board. See Issues flashing the printer board and in particular make sure you configure for the MCU that is REALLY installed on your board.
Please see images below. Thanks for your help, hope some of these give you a clue to what on earth i’ve gotta do resolve the issue.
Could it be a power supply issue as currently the Motherboard is only powdered by the Pi as i have not installed it in the printer?
Unfortunately the screenshots are of no use and you cannot show the issue with screenshots.
Again: Your connection string /dev/serial/by-id/usb-LeafLabs_Maple-if00 clearly indicates that the board is not flashed with Klipper.
Follow the instructions given in the link above and in particular verify that the MCU on your board is actually what you use for compiling the firmware.
i was trying to show you that when i run the command to find my mcu out that it returns ‘/dev/serial/by-id/usb-LeafLabs_Maple-if00’
you can also see that klipper is install on the pi and i have used winscp to extract the klipper.bin file install on the pi.
i have used 3 different sd cards all reformatted to fat32 along with 3 different cables, i have two of the same motherboards (btt skr e3 v2) both returning the same mcu ID.
i have double checed the chip is correct and the bootloader is also
Show a screenshot of your make menuconfig settings and a screenshot of the printer board where the markings on the MCU can be read.
this? and
thanks!
How, when and where did you build the firmware for the board?
In doubt refer to build-and-flash-the-firmware
I’ve just remade it and tried to flash it again and still getting the same.
Sorry for interjecting here but the size of klipper.bin doesn’t look right.
I just built my own version of the firmware using the instructions here:
and selecting the 'F429:
and then when I look in the ~/klipper/out directory:
Version: v0.12.0-379-gf2e69a370
  Preprocessing out/src/generic/armcm_link.ld
  Linking out/klipper.elf
  Creating hex file out/klipper.bin
orangepi@orangepicm4:~/klipper$ ls out -l
total 1708
-rw-r--r-- 1 orangepi orangepi   11488 Dec  3 16:41 autoconf.h
lrwxrwxrwx 1 orangepi orangepi      32 Dec  3 16:41 board -> /home/orangepi/klipper/src/stm32
drwxr-xr-x 2 orangepi orangepi    4096 Dec  3 16:41 board-generic
-rw-r--r-- 1 orangepi orangepi      27 Dec  3 16:41 board-link
-rw-r--r-- 1 orangepi orangepi   72794 Dec  3 16:42 compile_time_request.c
-rw-r--r-- 1 orangepi orangepi     353 Dec  3 16:42 compile_time_request.d
-rw-r--r-- 1 orangepi orangepi  227784 Dec  3 16:42 compile_time_request.o
-rw-r--r-- 1 orangepi orangepi   17771 Dec  3 16:42 compile_time_request.txt
-rwxr-xr-x 1 orangepi orangepi   31872 Dec  3 16:42 klipper.bin
-rw-r--r-- 1 orangepi orangepi    9382 Dec  3 16:42 klipper.dict
-rwxr-xr-x 1 orangepi orangepi 1373188 Dec  3 16:42 klipper.elf
drwxr-xr-x 4 orangepi orangepi    4096 Dec  3 16:41 lib
drwxr-xr-x 4 orangepi orangepi    4096 Dec  3 16:42 src
As I understand it, Klipper firmware for basically any MCU should not be less than 30k.
What is the process (and parameters) that you used for building your version of Klipper?
hello, thanks for your help!
i used make config in the klipper directory
I have the skr mini e3 v2 motherboard.
This is why we ask people to be precise with the information that they provide - You did not specify “SKR Mini E3 V2” in the original post. Grumble.
Regardless, two comments:
  1. Could you do a ls ~/klipper/out -l and see if it matches:
total 1420
-rw-r--r-- 1 orangepi orangepi   11484 Dec  3 17:15 autoconf.h
lrwxrwxrwx 1 orangepi orangepi      32 Dec  3 17:15 board -> /home/orangepi/klipper/src/stm32
drwxr-xr-x 2 orangepi orangepi    4096 Dec  3 17:15 board-generic
-rw-r--r-- 1 orangepi orangepi      27 Dec  3 17:15 board-link
-rw-r--r-- 1 orangepi orangepi   66579 Dec  3 17:16 compile_time_request.c
-rw-r--r-- 1 orangepi orangepi     353 Dec  3 17:16 compile_time_request.d
-rw-r--r-- 1 orangepi orangepi  217612 Dec  3 17:16 compile_time_request.o
-rw-r--r-- 1 orangepi orangepi   16013 Dec  3 17:16 compile_time_request.txt
-rwxr-xr-x 1 orangepi orangepi   29644 Dec  3 17:16 klipper.bin
-rw-r--r-- 1 orangepi orangepi    8426 Dec  3 17:16 klipper.dict
-rwxr-xr-x 1 orangepi orangepi 1096416 Dec  3 17:16 klipper.elf
drwxr-xr-x 4 orangepi orangepi    4096 Dec  3 17:15 lib
drwxr-xr-x 4 orangepi orangepi    4096 Dec  3 17:16 src
This is what I got when I built with your parameters and maybe the Folder view that you are using is rounding the size but even with that there seems to be a discrepancy there.
  1. If you’re comfortable that the build is correct, could you try building with pin PA13 (SWDIO) set? This will turn on the STATUS LED on the board:
If you turn on/off the STATUS LED in your firmware, you will get a positive indication that you are changing the firmware.
Normally when the board turns on, you will get one LED lit on the left side of the LED that I’ve marked here:
If PA13 is set and the BTT SKR Mini E3 V2 is programmed correctly, then you’ll have both LEDs lit.
If they’re both set then you can follow the instructions @Sineos and @EddyMI3D are giving you, knowing that you are updating the firmware on your main controller board.
Make sure to:
Hello, Sorry for the slow reply
Here is what i got below.
i will have a go at the PA13 now.
Sorry for not being more specific on my board!
both lights are on now
and…
Success!
Thank you mykepredko, Sineos & EddyMI3D! I was truly out of my depth
