Printer Model: Ender 3
MCU / Printerboard: SKR mini e3 v2
Hey guys, so I have been trying to get my printer running klipper for about 2 weeks now and am scared I may have messed it all up. I was running mainsail with my RPI 3b but kept getting mcu errors. Found out it was because I wasn’t successfully uploading the klipper firmware to my mcu, which was the original mcu that came out in 2018, so I decided to upgrade to the mini e3 v2. I installed the mcu and it seemed to be working fine, screen worked and I had all settings available, still no mcu connection on mainsail. I tried flashing klipper firmware.bin that i built in kiauh, didnt seem to upload. searched around and figured I needed to download the bootloader for the SKR. followed a guide I found and when I powered on with the sd card the printer turned on and the screen was blank. I let it sit awhile since most videos had the same thing happened. Now the screen has been stuck like that every boot, blank glowing blue, no words. I decided to restart completely, this time I used fluidd. Only problem is I still cannot connect MCU and the screen is still blank, and when i try to flash the firmware with kiauh, it says no mcu detected/connected. when i put ls /dev/serial/by-id/* I get ls: cannot access ‘/dev/serial/by-id/*’: No such file or directory. So since I tried uploading the bootloader it seems my mcu hasnt responded. I still get lights on the board and the screen lights up but thats it. Any ideas? PLEASE HELP ME
