Ender 3 pro btt skr mini v3 no mcu
Printer Model: ender 3 pro
MCU / Printerboard: big tree tech skr mini v3
im trying to get klipper to run on my ender but i keep getting a message on mainsail that mcu is unable to connect. im not sure what im doing wrong any help would be great
klippy (2).log (501.8 KB)
Hello @bsavage710 !
Did yo follow a certain guide?
How did you obtain the serial ID?
serial = /dev/serial/by-id/usb-Klipper_Klipper_firmware_12345-if00
i fixed it reflashed firmware to ender 3 pro then everything just worked. thank you for responding.
im stuck on bed mesh its not working properly itll fail mid way i have bl touch set up
[stepper_x]
step_pin: PB13
dir_pin: !PB12
enable_pin: !PB14
rotation_distance: 40
endstop_pin: ^PC0
position_endstop: 0
position_max: 230
homing_speed: 50
[tmc2209 stepper_x]
uart_pin: PC11
tx_pin: PC10
uart_address: 0
run_current: 0.580
stealthchop_threshold: 999999
[stepper_y]
step_pin: !PB10
dir_pin: !PB2
enable_pin: !PB11
endstop_pin: ^PC1
position_endstop: 0
position_max: 230
homing_speed: 50
[tmc2209 stepper_y]
uart_pin: PC11
tx_pin: PC10
uart_address: 2
run_current: 0.580
step_pin: PB0
dir_pin: PC5
enable_pin: !PB1
rotation_distance: 8
position_max: 250
position_min: 0
[bltouch]
sensor_pin: ^PC14
control_pin: PA1
## Offset for Hero Me 6
x_offset: -40
y_offset: -16
z_offset:  1.700 # Uncomment if starting fresh; Distance should be enough to keep the z-offset positive.
speed: 3.0
samples: 2
samples_result: median
sample_retract_dist: 6.0
samples_tolerance: 0.02
samples_tolerance_retries: 5
[bed_mesh]
speed: 120
horizontal_move_z: 1.700
mesh_min: 14, 14
mesh_max: 100,100 #this may need to be calibrated for your individual printer
probe_count: 5,5 #this is the number of probing points on X then Y axis
mesh_pps: 2,2
fade_start: 1
fade_end: 10
fade_target: 0
[safe_z_home]
home_xy_position: 115.00, 115.00 # Change coordinates to the center of your print bed
speed: 50
z_hop: 5                 # Move up 10mm
z_hop_speed: 5
PLEASE!
Upload code as a file or at least use the Preformatted Text feature of the forum editor to put it into the right form. Things can be messed up without.
Format
Move out of range: 240.000 30.000 1.700 [0.000]
12:14 PM
probe at 192.500,30.000 is z=1.540000
12:14 PM
12:14 PM
Probe samples exceed tolerance. Retrying...
12:14 PM
probe at 192.500,30.000 is z=1.557500
12:14 PM
probe at 192.500,30.000 is z=1.535000
12:14 PM
probe at 145.000,30.000 is z=1.540000
12:14 PM
probe at 145.000,30.000 is z=1.532500
12:14 PM
probe at 97.500,30.000 is z=1.617500
12:13 PM
probe at 97.500,30.000 is z=1.605000
12:13 PM
probe at 50.000,30.000 is z=1.642500
12:13 PM
probe at 50.000,30.000 is z=1.660000
12:13 PM
BED_MESH_CALIBRATE PROFILE="default"
type or paste code here
[stepper_x]
step_pin: PB13
dir_pin: !PB12
enable_pin: !PB14
endstop_pin: ^PC0
position_endstop: 0
position_max: 230
homing_speed: 50
In line 9 the size is smaller than you tried to probe.
Please open a new thread for this issue is different to that one that is already solved. Please attach all requested information.
