Mcu 'mcu': Unable to connect ender 3V2
Printer Model: ender 3 V2
MCU: ender 3 V2 stock mainboard (creality 4.2.2 mainboard)
I have recently been trying to upgrade my ender 3 V2 to get better print quality, I have installed a creality sprite extruder and CR touch as well as a second Z axis lead screw. I recently have been trying to run klipper firmware so I found a guide (How to Install Klipper on the Ender 3 (With Mainsail OS) | Obico Knowledge Base) and followed all of the instillation steps. I got my raspberry pi model 4B up on wifi and opened up the mainsail web interface and got this error:
mcu ‘mcu’: Unable to connect
Error configuring printer
when hitting restart firmware it says this:
Moonraker can’t connect to Klipper!
Please check if the Klipper service is running and klippy_uds_address is correctly configured in the moonraker.conf.
how can I fix this issue?
edit: I got it working! after reinstalling everything I believe the issue was with the makemenuconfig step.
i missed the step that said to select “serial (on USART1 PA10/PA9)”
for anyone else reading this struggling with similar problems, make sure to reread the config file for your printer multiple times to not miss anything
I had the exact same problem a littie while ago, but i cant remember how i fixed it.
I did a search on reddit and found the answer there, I’ll have a look there and get back to you .
I suggest joining the Klipper discord. They’ll be able to help you out the best.
This is where i found my answer sorry i cant find the conversation where they told me how but ask your question here and im sure they will help you, sorry i couldn’t be more help
I suggest to provision a new SD card with Mainsail OS and then use KIAUH to install all relevant items.
Probably easier and faster than searching for the issue.
i reinstalled and updated everything on a fresh install of mainsail but now I’m getting this error:
Unable to open config file /home/pi/printer_data/config/printer.cfg
Printer is halted
Well the error messages should be quite self explaining: You need to provide a proper printer.cfg to the installation.
You could for example follow the guide you already used How to Install Klipper on the Ender 3 (With Mainsail OS) | Obico Knowledge Base and start with Log in to Mainsail OS and configure Klipper for Ender 3
I have the printer.cfg file on the web interface but it says it isn’t on the pi itself.
  1. Download the config you need:
    grafik
  2. Modify it with your MCU serial
  3. Upload it again as printer.cfg
