Printer Model: Custom printer (with MKS Gen v1.1) and an Ender3
klippy (1).log (103.1 KB)
moonraker.log (34.4 KB)
(Both klippy.log and moonraker.log are from the custom printer, named hypercube)
I recently installed klipper on a 3d printer that I built, and it worked fine.
But I wanted to add klipper for my Ender 3 printer.
So I uploaded the klipper firmware to the Ender 3, and then I completely reset my raspberry pi (4B), to reinstall klipper from scratch, for 2 printers.
After some settings, with 2 klipper instances (with mainsail), and being careful to put the write mcu in the printer.cfg, I successfully connected to the web interface, and connected the 2 printers (it shows a green cross).
Note: When I try to connect to the http://raspberrypi web interface, I can access to mainsail, but it can’t connect to the printers (it shows a red cross). I then found out that I need to connect from the IP address (192.168.1.27). I don’t know why, because it is supposed to be the same address
My problem now is that, after struggling for a long time, I still have the mcu problem, with both printers.
Maybe for the Ender 3, the settings are not good, for the printer.cfg, or other… maybe for the firmware I installed is a wrong one, but for the HyperCube, I am sure that the settings work, because it worked before, when I only had the HyperCube connected to klipper.
If anyone has any solution to suggest, I would be very grateful.
Thanks in advance!
PS : Sorry for my English, I am not native.
